Thread: High NOX
Results 1 to 3 of 3
  1. #1 High NOX
    SE Level Member Justin48's Avatar
    Groton, CT
    Hey all i have a 02 gtp and need to get a cali smog check to get base tags... *bull**** when i have washington plates* but getting a stock tune pcm back in the mail and going to put the stock airbox in. but with a tuned pcm and fwi the NOX levels where off the charts. any idea if stock air box and tune will fix that? if not know of what i need to check to fix it? thanks!
  2. #2 Re: High NOX
    Apr 2009
    stockton ca
    nox is from running hot sounds like your running lean and possably have a failling cat
  3. #3 Re: High NOX
    true, if the car was running well, even if modded, it would pass a sniffer test (so long as you have a cat).
  1. No High Beams
    By taximech in forum General Tech Discussion
    Last Post: 06-23-2009, 11:37 AM
  2. How High Is To High?
    By samsquanch in forum General Tech Discussion
    Last Post: 06-17-2009, 12:29 AM
  3. High Amp Alt vs. Bigger Cap
    By adidasdude1061 in forum Audio, Security & Visual Electronics
    Last Post: 04-19-2009, 04:52 AM
  4. High Flo Cat
    By 04gpking85 in forum General Tech Discussion
    Last Post: 09-15-2008, 01:24 AM
