Thread: down pipe
Results 1 to 14 of 14
  1. #1 down pipe
    GT Level Member wlmrt6's Avatar
    Sterling
    Im looking at down pipes for my 05 gtp and im not sure what options i will need. i was looking on zzp. I want to keep it street legal and occasional strip car. any help?
  2. #2 Re: down pipe
  3. #3 Re: down pipe
    Sterling
    alright does it come with a high flow cat or do i use my stock one?
  4. #4 Re: down pipe
    Sterling
    also do i need the o2 thing for 04+ gtp?
  5. #5 Re: down pipe
    a bolt in pipe WITH CAT will come with a high flow cat.
    you may or may not throw the P0420, you wont know until you run it.
  6. #6 Re: down pipe
    May 2008
    I have a 3" race DP for sale if you want it. No O2 bung though.
  7. #7 Re: down pipe
    Sterling
    what exactly is the p0420? is that the o2 sensor?
  8. #8 Re: down pipe
    thats the rear o2 sensor being disconnected or cat inefficiency code.
  9. #9 Re: down pipe
    Sterling
    ok well id get really annoyed if it kept tellin me to check my engine. will i notice gains if i get this zzp down pipe a wizaired intake and a 180 degree tstat?
  10. #10 Re: down pipe
    Jul 2008
    sumter,south carolina
    t stat will do nothing for u... but u will feel some extra get up with downpipe and intake.
    02 GTP with mods 05 GP for DD
  11. #11 Re: down pipe
    Sterling
    ok cuz i have a ****ty autozone cone filter it sounds cool but i don't think its doin much. should i get the tstat or no?
  12. #12 Re: down pipe
    Jul 2008
    t stat will do no good, your fans arent set to come on at 180*... need a tune to benefit 180 t stat..... that comes further down the line into modding.
  13. #13 Re: down pipe
    MA
    how far are you looking to take the car? you should consider headers you can get them for almost as cheap as the dp with a powerlog to replace your front manifold( which is another restrictive area in the factory exhaust setup).
    SMGPFC Member #9
  14. #14 Re: down pipe
    Sterling
    i was thinkin the ported manifolds after the down pipe. i want to do alot but i dont want to do a smaller pulley. i would be happy running 14.2 in the 1/4 i run a 14.83 now
  1. I just put a down pipe on my o4 gtp need help ?
    By 98gtp1000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2009, 12:39 AM
  2. Down pipe
    By JB Miller in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-18-2009, 12:40 AM
  3. Which down pipe should I get?
    By Baron in forum General Tech Discussion
    Last Post: 04-10-2009, 12:14 AM
