i appreciate all of the feedback that you have given!
i have swapped the coil packs and pulled and replaced the front 3 plugs and wires. i am having one heck of a time getting to the back 3 (especially the 2 plug.) i have removed the front motor mounts and have a little wiggle room. i am using prj wires; should i throw the stock heat shields on these prj wires? it seems a bit restrictive.....
do you have any suggestions on getting to those plugs in the back? can i actually jack the motor from the oil pan with wood?
also, do you recommend i change anything else in this tune up? i have swapped the air filter and i am putting in a 180 thermostat. any suggestions you can give are greatly appreciated!
have a good one,
mike
