Thread: Idleing with 65# inj
Results 1 to 20 of 22
  1. #1 Re: Idleing with 65# inj
    GT Level Member TurboKent's Avatar
    Woodward, OK
    mine usually will run alittle rough at idle with a misfire here and there but if i turn on the ac while in park it will smooth out. I think i'm gradually getting it worked out by maf/Ve tuning. If i find the cure that stops it for sure i'll let you know.
  2. #2 Re: Idleing with 65# inj
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Does yours ever surge? I just put my stock inj back in and ran the car on a stock tune and it still seemed to run "rough". I am not sure how it is supposed to sound anymore though. What are you mods Kent? Was your car worse before you started VE/Maff tuning. Also is there a chance you could pm me your IFR table, if you are using pt, or if not that could I pm you mine so you can compare them and make sure I am close to yours. I just did the math method 35/65= whatever it is.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  3. #3 Re: Idleing with 65# inj
    New Salem, ND
    Quote Originally Posted by TurboKent View Post
    How did yours run right after the turbo install?
