I don't believe the inj spacers will work with anything bigger than a SSIC. There are cheaper option for fuel rails out there. Check out some of the vendors, I know that ZZP sells modified stock rails that will work with their S2 IC and I believe they are under $200. As far as checking for clearance you could get a bunch of playdough or something along that line and pile it on top of the blower, close the hood (and then reopen hood) and then measure how thick it is after being compressed by the hood. That should give you the exact dimension for clearance.
