Thread: PCV Valve and Retainer for Gen V Supercharger
Results 1 to 10 of 10
  1. #1 PCV Valve and Retainer for Gen V Supercharger
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    How do u know exactly if the pcv valve is bad?
    And the black platic retainer at the bottom that goes under the pcv valve, it has 5 or 6 thread looking rings on it, do i have to push it down in till it stops and just pop it in the port for it and im good?
    i have pictures of what im talking about if someone needs them.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  2. #2 Re: PCV Valve and Retainer for Gen V Supercharger
    Banned - Busted For Scamming
    Feb 2009
    No those have nothing to do with it, just the design. Its good if you can rattle the pcv valve and the valve moves freely. It goes plastic retainer, pvc valve, o ring, spring, cover.
  3. #3 Re: PCV Valve and Retainer for Gen V Supercharger
    so the plastic retainer just slips in then? no pushing it down? just want to clarify lol
    also on a side note mini, with those silicond baking sheets for s/c gaskets, do u also put a layer of rtv on or just cut them and put them on and be done?
  4. #4 Re: PCV Valve and Retainer for Gen V Supercharger
    Feb 2009
    Cut them put them on and done. No rtv. They conform and seal fine. Did you get some?
    Im not sure what you are asking when you say push down on the plastic retainer? When you drop it in, you should take a 3/8" extension and push it down in there until the plastic piece bottoms out.
  5. #5 Re: PCV Valve and Retainer for Gen V Supercharger
    ya thats exactly what i was trying to get at. I took the PCV cover and valve out to check everything. turned the supercharger over and that retainer just fell out. And the O-ring on the pcv valve was weak so i put a new one on.
    And ya i got 2 sheets being shipped to me from target.com
  6. #6 Re: PCV Valve and Retainer for Gen V Supercharger
    are u sure the o-ring goes under the spring or does the o-ring go on the bottom of the pcv valve?
  7. #7 Re: PCV Valve and Retainer for Gen V Supercharger
    Feb 2009
    Well you put it in before the pcv valve, and then you install the pcv valve. Use a dab of oil to make sure things glide smoothly.
  8. #8 Re: PCV Valve and Retainer for Gen V Supercharger
    alright sweet. thanks for the help Logan. This was probably the reason for the oil in the intake.
  9. #9 Re: PCV Valve and Retainer for Gen V Supercharger
    Feb 2009
    No problem. Just keep in mind that eventually oil vapor will make a thin film but just make sure its not too much.
  10. #10 Re: PCV Valve and Retainer for Gen V Supercharger
    you can always expect a small amount of residue everywhere in the motor.
  1. Important: ZZP Retainer Issues
    By BillBoost37 in forum General Tech Discussion
    Last Post: 04-04-2012, 10:29 AM
  2. supercharger blow off valve?
    By 2story in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2011, 06:24 PM
  3. Pcv valve
    By Madness in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-24-2010, 12:16 PM
  4. EGR Valve! What does it do?
    By Bruty74 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-24-2009, 09:40 PM
  5. EGR Valve?
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2008, 10:24 PM
