Thread: safe??
Results 1 to 10 of 10
  1. #1 safe??
    GT Level Member wlmrt6's Avatar
    Sterling
    alright i have an 05 gtp. ive got a zzp 3" downpipe with high flow cat, powerlog, ported rear manifold, ceramic coated crossover pipe, 180* tstat, k&n fipk intake. im looking into getting a 3.6 pulley i was thinking throttle body spacer, 1 heat range colder plugs and a tune would also be changing the s/c oil. would i be safe doing this? and if u guys have any advice let me know
  2. #2 Re: safe??
    3.6" should be fine...don't waste your money on the TB spacer though. Get the plugs and if you plan on modding more get bigger wires. Just get a way to scan to be sure though.
  3. #3 Re: safe??
    Sterling
    yea i have a guy thats got an hp tuner that shows kr.
  4. #4 Re: safe??
    Charles City, IA
    Yup a tb spacer is useless. Good tune will be your best friend and a good way to scan.
    SMGPFC Two Nipple General
  5. #5 Re: safe??
    Sterling
    alright i ran a 14.70 with what i got now and my goal is about a 14.00 in the 1/4 so i figured pulley was the only way there
  6. #6 Re: safe??
    Sterling
    what ngk plugs would you guys recommend?
  7. #7 Re: safe??
    Autolite...104's.
  8. #8 Re: safe??
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    why Autolites and not NGK?
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  9. #9 Re: safe??
    Sterling
    yea ive heard ngk have a longer life.
  10. #10 Re: safe??
  1. Will this be safe?
    By Silver GTP in forum General Tech Discussion
    Last Post: 06-08-2010, 01:07 PM
  2. Is this safe?
    By Amb4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2010, 09:48 PM
  3. are Reprogrammed PCM safe?
    By Charlie in forum General Tech Discussion
    Last Post: 11-02-2009, 02:00 PM
  4. Safe to run 3.2?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 09-25-2009, 11:20 AM
  5. This looks like fun & safe
    Last Post: 06-29-2008, 09:13 PM
