Thread: Diagnosing something moving that shouldnt (not a motor mount)
Results 1 to 5 of 5
  1. #1 Diagnosing something moving that shouldnt (not a motor mount)
    SE Level Member GeeBee's Avatar
    Iowa
    Ok so just got done replacing all my motor mounts with solid poly mounts, still have something moving on hard accelerations. Also full solid poly mounts is damned annoying in gear at a stoplight.
    Any ideas for whats causing this? loose / bad Cradle mounts, strut mount?
    the CV joints felt good and at higher speeds it has no funky vibrations
    2006 Grand Prix Gt - Wizair, Solid Poly Mounts
    1996 Olds 98 Regency Elite - Dieing of Car Cancer and old age.
  2. #2 Re: Diagnosing something moving that shouldnt (not a motor mount)
    can you describe 'something is moving'?
    also, why in gods name did you put poly mounts on the bottom end? youre never going to get rid of that vibration at stop lights now. you should have done poly uppers and just regular solid lowers.
  3. #3 Re: Diagnosing something moving that shouldnt (not a motor mount)
    Iowa
    I really thought it was the motor mounts, it would bang when i put it in reverse almost everytime i pulled out of my driveway, which has a little bit of an incline. And and on hard acceleration from a stop it would knock. TBH i havent put it in reverse to back it out of the driveway yet to see if it does the same.
    Could it be play in the drivetrain since i come home from work, go up the drive then put it in park, then when i go to leave it goes from max tension forward to reverse?
    And yes the solid poly bottom end will prolly get removed, it started making my doors rattle silly at the stoplight.
  4. #4 Re: Diagnosing something moving that shouldnt (not a motor mount)
    Oct 2008
    Northern Illinois
    Check out my thread in the 3.8 s/c section, sounds like we have the same problem. Is yours doing the same thing like the video I posted?
  5. #5 Re: Diagnosing something moving that shouldnt (not a motor mount)
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    GeeBee, what you are describing kinda sounds like your tranny might be the cause... just a thought.
    98' GTP, 18's, BMR Adjustable Forward & Rear Lateral Arms, BMR Tubular Trailing Arms, Intense PCM, CAI, drilled rotors, 5% Tint all around
  1. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
  2. GreenNirvana's Motor Mount
    By UR LOSN in forum Off Topic Discussion
    Last Post: 07-03-2008, 08:13 PM
  3. Anyone Want To Buy A Motor Mount? What About an Axle? Lol
    Last Post: 06-29-2008, 11:01 AM
  4. Motor mount help for 94 GP
    By 954mula in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-07-2008, 12:02 AM
