Thread: p0121 code
Results 1 to 15 of 15
  1. #1 p0121 code
    Jul 2008
    sumter,south carolina
    i know its a TPS code,but i put in a brand new TPS yesterday....cleared code and it popped back on today.Any thoughts on why it would go bad already?Not sure if it has any value but my boost indicator light on DIC is acting screwy too...either doesnt work or it gets stuck halfway. car idles at around 600-700 rpms and wants to stall when i come to a stop.
    02 GTP with mods 05 GP for DD
  2. #2 Re: p0121 code
    May 2008
    staten island,NY
    i believe that if the boost on the DIC is screwy it has something to do with the MAP sensor. but the code you threw is
    TPS/pedal position sensor A CKT range/perf
  3. #3 Re: p0121 code
    Jul 2008
    yea ZEF answered my question in another thread about that problem about the boost light...i wasnt sure if that might be all tied into this TPS code...i dunno if i got a bad sensor from auto zone or if something is causing it to go bad.any other ideas?
    or is TPS/pedal position sensor 2 seperate sensors?
  4. #4 Re: p0121 code
    May 2008
    staten island,NY
    i have gotten bad sensors before, i think if you check the TPS for voltage somewhere it will tell you if its bad. i dont know for sure. we dont have electronic throttle so i dont see the gas pedal having a sensor other than the TPS
  5. #5 Re: p0121 code
    Jul 2008
    thanks,i guess ill take it back and get another one...just to clarify...the TPS is a simple screw in right...take old one out put new one in and thats it?
  6. #6 Re: p0121 code
    Jul 2008
    OK before i take this TPS back today,can anyone think of a reason that it went bad over night...another problem causing it to go bad? thanks in advance! i reset code after it tripped with the new one....it ran fine all day..then trippped again last night
  7. #7 Re: p0121 code
    hamburg
    im having the same problem and im on my 4th tps need help asap
  8. #8 Re: p0121 code
    chicago
    i don't think the tps is bad, think it's trying to reset itself. happened to me a month ago. i was unplugging it and and messing with it. it stalled on me 4 different occasions and also wanted to die at the stop light. the check engine even came on. have you try to remove the code cause that's what i done on mine. drive fine now.
  9. #9 Re: p0121 code
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    how are u putting the TPS sensor in? theres a certain way to put it in otherwise it will be all screwy.
  10. #10 Re: p0121 code
    technically it should only be one way IMO...if it don't work one way flip it around then it should work.
  11. #11 Re: p0121 code
    How can it work if its flipped around?
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  12. #12 Re: p0121 code
    hamburg
    no its in right and the code is pending
  13. #13 Re: p0121 code
    Quote Originally Posted by bbptech View Post
    It won't...that is the trick.
  14. #14 Re: p0121 code
    SE Level Member jessiinicole's Avatar
    Florida
    I have a 98 GTP identical to yours. I accidently drove about 18 miles in 3rd gear.. (not paying attention) luckily i caught it in-time before serious damage, back to point since then my car has been doing the exact same thing. My boost will get stuck on 6-7 bars, RPM's jump to 5,000 + when getting into it to pass, had died a few times the day it ( 3rd gear accident happened) but thankfully stopped. When i initially clear the check engine light it runs fine again, except for the fact my boost indicator doesn't work at all...?? Until chk engine comes back on but then it is stuck at 6-7 bars!?!
    JuSt A gIrL
  15. #15 Re: p0121 code
    SE Level Member corsagtp's Avatar
    Calgary, AB
    Quote Originally Posted by jessiinicole View Post
    Just because you drove 18 miles in 3rd gear doesn't mean it's going to do damage, on the highway, yes it could, but if your doing city driving and going under 50 mph it wouldn't hurt anything
    97 GTP - POS parked in backyard
    07 Saab 9-3 2.0 turbo 6-speed - Awesome
  1. I got a code!!!???
    By justwhisen in forum General Tech Discussion
    Last Post: 04-14-2010, 07:22 PM
  2. P0440 code
    By Z28 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-14-2008, 04:32 PM
  3. Troubleshooting Help! p0120 & p0121
    By Lawngoose in forum General Tech Discussion
    Last Post: 10-25-2008, 05:10 PM
  4. Anyone know a paint code?
    By Reptile in forum Off Topic Discussion
    Last Post: 08-12-2008, 03:30 PM
  5. paint code
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 04-13-2008, 08:41 PM
