Thread: few questions.
Results 1 to 20 of 25
  1. #1 few questions.
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    Gonna put the stock cam back in for the summer until i start school and then put the XPZ back in possibly or a different cam. Not sure yet. But that way while im in school i can learn all the good stuff on cams that i dont know. like degreeing and such. my questions are:
    1. I have ZZP CNC Ported heads that will be staying on, stock valve springs will be put back on as well. Do the cnc ports have the longer valves? i though i read the are .100 taller but not sure?
    2. can i run my (12) 7.05 length pushrods cause i dont have my stock pushrods anymore?
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  2. #2 Re: few questions.
    they dont have longer valves. the valve guides are machined an extra .100" to accomodate higher lift cams and rocker ratios.
    im sure you can run the 7.05s, isnt stock 7.10?
  3. #3 Re: few questions.
    stock is 7.02 IIRC. Should i at least get some 1.9 modded rockers for time being?
    So everything will work stock wise with these zzp cnc ports?
  4. #4 Re: few questions.
    yeah, the heads shouldnt make a difference. the guides are just milled so that if you wanted to use that extra lift you could.
    i dont see why itd be bad to run rockers except itd be a waste of money if you plan on putting a cam back in it at some point.
  5. #5 Re: few questions.
    Why are you taking it out anyways? I see lots of sand in your future
  6. #6 Re: few questions.
    what do u mean blue? its coming out just for numerous problems. Ill have more of the know how to set up the valve train and everything while im in school ya know.
    Ya ur right on that bio.
  7. #7 Re: few questions.
    Donating Users blowfishRus6's Avatar
    g.a.
    should have stuck with the intense cam........
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  8. #8 Re: few questions.
    the stage 4??? i wish i could just have 10 l67's and try out each cam. maybe when i win the lottery
  9. #9 Re: few questions.
    i think the xpz cam i have isnt right. looking at the cam card, none of the specs match what other specs ive been looking at like on the Comp Cams site.
  10. #10 Re: few questions.
  11. #11 Re: few questions.
    who? ZZP? or comp cams?
  12. #12 Re: few questions.
    the cam comes from comp or from zzp? do they have stock of them at their place or do they just ship them out of comp? that will answer your question.
  13. #13 Re: few questions.
    cam is from zzp. bought it when i was there.
  14. #14 Re: few questions.
    g.a.
    and they gave you the wrong cam................
    damn zzp
    its slow.
  15. #15 Re: few questions.
    this is off the how to section under "camshaft information" :
    ZZP XPZ: 217/225 .352/.333 116 N/A
    This is the cam card that came with my cam brand new from ZZP:
    Those numbers should match right?
  16. #16 Re: few questions.
    g.a.
    call zzp.....
    wake turbo tim up.
    its slow.
  17. #17 Re: few questions.
    well, the lift numbers you posted read like this:
    .352" x 1.6 = total intake lift = .5632"
    .333" x 1.6 = total exhaust lift = .5328"
    therefore, the listed numbers sound a little off and the cam card is probably right.
  18. #18 Re: few questions.
    ZZP FTW yet again
  19. #19 Re: few questions.
    the email i just got from him an hour ago asking for the specs of the cam, he said "the specs are on the intense site when they compared one. The cam card isnt that accurate"
  20. #20 Re: few questions.
  1. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  2. 04+ FWI Questions
    By ZR1Vette09 in forum General Tech Discussion
    Last Post: 11-11-2009, 12:43 AM
  3. Looking for a new GTP and have a few questions
    By nawarkk in forum General Tech Discussion
    Last Post: 09-18-2009, 01:05 PM
  4. I've got a few questions
    By josemolina2008 in forum General Tech Discussion
    Last Post: 08-23-2009, 09:55 PM
  5. New - A few questions please
    By lioneyes in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-02-2008, 07:48 PM
