Thread: Need help spending some money (This should be easy)
Results 1 to 20 of 23
  1. #1 Re: Need help spending some money (This should be easy)
    SE Level Member GTP2K1's Avatar
    Tampa, FL
    Couple of things I haven't seen mentioned that could save you some money. The first being the Machined Lower Intake Manifold, you don't need that with the Short Stack Intercooler. The next being the Ported Supercharger, its way too soon in my opinion to be looking at that as a mod for your setup. That more for when your going smaller then a 3.0 pulley an outlet temps on the blower are a serious concern because your pushing the stock M90 so far past its original efficiency range. An the TB is more or less just to match the blower inlet. With the larger ones you can feel a difference in throttle response but your not getting any faster till your car needs more air then the stocker can supply.
    If I were you I would do the Rockers (modified stock 1.9) an the 3.4 next an then spend some time tuning it in, probably have to add a little fuel to quench any little blips of knock. You should also be in the 13's with an equal launch, if you managed a 14.4 with what you have now.
    By then the mod bug will have bitten an you will rethink your entire plans an goals for the car. But until then enjoy your goal.
    Cheap, Fast, Reliable... you can only pick two
    http://www.cnfcgp.com/
  2. #2 Re: Need help spending some money (This should be easy)
    TDCRacing
    Guest
    Quote Originally Posted by GTP2K1 View Post
    Well i think sometimes it is the little things that count...(porting ect) can make a difference...it defenitly wont hurt...I know as far as the money...i would get more bang for my buck with something else and i think that is the point you were trying to make...but i do appreciate your input and help....i think the mod bug has bitten me again lol...just want to have everything ready (porting wise) for when i go splurging.
  3. #3 Re: Need help spending some money (This should be easy)
    TDCRacing
    Guest
    Anybody have any input on the intercoolers or nos????
  1. Easy Dent Removal
    By SyntheticShield in forum Visual/Body Modifications
    Last Post: 04-04-2008, 05:17 PM
  2. Money from the government?
    By N3p in forum The Rant Forum
    Last Post: 03-19-2008, 04:01 PM
  3. So I found an easy how to on carbon fiber panels
    By s1795so2 in forum Visual/Body Modifications
    Last Post: 01-22-2008, 05:13 PM
