Thread: Blowing MAF Fuse, SES Light, P0102
Results 1 to 20 of 21
  1. #1 Re: Blowing MAF Fuse, SES Light, P0102
    May 2008
    staten island,NY
    yea but we swapped the fuse on jeffs car and it blew again, as well as the code came back after i cleared it. i think theres a short somewhere, let us know if the fuse blows again
  2. #2 Re: Blowing MAF Fuse, SES Light, P0102
    GT Level Member shawn3091's Avatar
    Jan 2009
    State College PA
    i had a major short a while back, mice chewed like 10 pcm wires and they were all touching each other still ran surprisingly
  3. #3 Re: Blowing MAF Fuse, SES Light, P0102
    SE Level Member 98RegalGS's Avatar
    Victorville, CA
    Quote Originally Posted by QwikGT View Post
    How long did it take to blow the fuse again?
    98 Regal Gs L67 SC. 3.4 Pulley, SLP CAI, 3" downpipe with no u-bend, resonator delete, TB spacer, TB heat shield, 17" Caddy CTS wheels.
  4. #4 Re: Blowing MAF Fuse, SES Light, P0102
    Aug 2008
    Long Island, New York
    Quote Originally Posted by 98RegalGS View Post
    not long, it varied a lil, once right after a 5 minute drive, once after a startup, once after a 45 minute drive. hopefully gettin the problem figured out next week when i bring it into the shop for the meth, and tuning and ****
  5. #5 Re: Blowing MAF Fuse, SES Light, P0102
    Victorville, CA
    Quote Originally Posted by 2000GTP View Post
    Good luck with it man. Can you explain to me what Meth injection is? Thanks
  6. #6 Re: Blowing MAF Fuse, SES Light, P0102
    Canada
    Fixed mine, performed an ohms test from MAF signal cable to the PCM pin, couldn't get a constant reading on it.
    Spliced in a new wire off the wire that runs out of the harness directly to the connector. All is good!
  7. #7 Re: Blowing MAF Fuse, SES Light, P0102
    Victorville, CA
    Quote Originally Posted by b34tBoX View Post
    Congrats on fixing it. Could you be a little more specific on where exactly you spliced the wire? You made a new wire all the way from the PCM to the MAF? Thanks
  8. #8 Re: Blowing MAF Fuse, SES Light, P0102
    Canada
    Using this diagram..
    http://sites.google.com/site/b34tbox/pcm_maf.jpg
    Looking down at your PCM, disconnect the top wiring harness.
    Remove gray plastic clip, just squeeze the sides and pull off.
    From there you can unbolt the adapter from the PCM and pull it out.
    There you will have access to the pins.
    Look for the pin labeled "69". It will be between another yellow and blue wire.
    Use a multimeter and set to ohms resistance.
    Disconnect MAF connector and probe yellow wire from MAF connector to pin 69.
    Try moving the connector and harness while you test to see if ohm reading changes, anything below 5ohms constant should be good, in my case when I moved the connector it spiked to over 100 and would fluctuate.
    I cut the yellow wire on the outside of the harness. leaving about 2 inches from PCM harness and routed a new wire up to MAF connector.
  1. blowing air,,but not hot
    By mimi in forum General Tech Discussion
    Last Post: 12-14-2010, 02:40 AM
  2. MAF Fuse Blowing
    By shoboy07 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2009, 07:05 PM
  3. fog light fuse
    By grand2000prixgtp in forum Audio, Security & Visual Electronics
    Last Post: 04-18-2009, 08:18 PM
  4. keep on blowing fuel pump fuse
    By libster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2008, 09:25 PM
  5. Interior Light Fuse Blows....
    By hester21289 in forum General Tech Discussion
    Last Post: 03-12-2008, 08:02 PM
