Thread: VS cam setup. Should I run rockers with it?
Results 1 to 10 of 10
  1. #1 VS cam setup. Should I run rockers with it?
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    I have a ZZP VS cam setup on my 97 gtp. It's strong and works great, but I see 2 degrees of KR up top every now and then that I wanna get rid of. I know that rockers help reduce KR and they start to kick in once you approach the higher revs. I am pondering a good set of 1.6 or 1.7's. Will I see a drop in KR up top with some slightly higher ratio rockers. I dont have a ported or bigger throttle body. Maybe that will help out more than the rockers? I also need an Idea of the power I might gain.
    I think my mods are in my signature, but its XS headers, vs cam, no res, Open Cone intake, 3.3 pulley 104's and 180 t stat tune ect.
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
  2. #2 Re: VS cam setup. Should I run rockers with it?
    i think rockers will take care of that KR, but it is a large amount of money to drop to not gain that much. i think youd be better off porting your blower and throttle body.
  3. #3 Re: VS cam setup. Should I run rockers with it?
    port the outlet of your blower.
    If you port your TB you'll need a retune.
    Get 1.7 RR's. Should help a little with the top end.
    But porting your blower outlet is the first thing I'd try since its the cheapest and effective.
  4. #4 Re: VS cam setup. Should I run rockers with it?
    Charles City, IA
    Need a better tune.
    SMGPFC Two Nipple General
  5. #5 Re: VS cam setup. Should I run rockers with it?
    Donating Users blowfishRus6's Avatar
    g.a.
    thats what i was going to say, im sure it could be tuned out.
    i would throw an ls1 tb on there and open up the incoming air, or atleast port your stocker.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  6. #6 Re: VS cam setup. Should I run rockers with it?
    I say put a bigger pulley on it, re-tune, and up the timing.
  7. #7 Re: VS cam setup. Should I run rockers with it?
    Nov 2009
    Michigan
    I tuned it out. I just dumped a little more fuel. It was running a little lean. Btw. I did port the blower outlet.
  8. #8 Re: VS cam setup. Should I run rockers with it?
  9. #9 Re: VS cam setup. Should I run rockers with it?
    g.a.
    PE vs A/F vs RPM vs TIME.
    DONT MESS WITH THAT SETTING!!!!! haha or atleast i hope you do better at it than i did. i did not relize it was supposed to spit that much fuel in over time and almost fubared a few things.
    glad to hear you got it worked out.
    its slow.
  10. #10 Re: VS cam setup. Should I run rockers with it?
    Nov 2009
    Michigan
    Quote Originally Posted by blowfishRus6 View Post
    Lol I didn't physically do it. I had it done by someone that knows these cars inside and out.
  1. Setup to go for?
    By Dthreap in forum Turbo
    Last Post: 01-26-2010, 08:50 PM
  2. my old setup
    By whitcomb in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 06:49 PM
  3. New setup
    By b00stinGTX in forum Brakes/Suspension/Chassis
    Last Post: 02-25-2009, 11:00 PM
  4. this setup
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2008, 08:47 PM
