Thread: well, got the car running after swap, but....
Results 1 to 6 of 6
  1. #1 well, got the car running after swap, but....
    SE Level Member NineD9GT's Avatar
    Dec 2008
    PA
    I'm getting two codes: P1676 and p0102. I have some other issues also... Non working temp gauge, the gear indicator on the inst. cluster doesn't work (and no backup lights) showing a low oil, and low coolant light on cluster, poor throttle response, and intermittantly working fans. One major concern I have is the car I got the wire harness out of was hit in the left front. (right at computer) Some of the wires had chaffing. I was wondering if this could be the root of all of my problems. I'm going to pull the computer out tomorrow morning and check it out. I'm not really asking for answers, just letting you guys know my progress, and maybe if you have any other places I can check.
    Just some info on my swap. 99 complete gtp cradle into my 99 gt. While I had the engine out, I replaced all gaskets on top end, added a 3.4 pulley, plugs, t stat, water pump, headers, supercharger coupler, trans filter, etc.. Once in the car, I added a magnaflow catback, and new struts. I have another thread started with my pics from the swap if you're interested.
    Like I said though, I'm gonna check those wires tomorrow and hope I find an obvious issue.
    99 GP GT L26 bottom end, Intense stage II cam, Ported L67 heads w/ LS6 springs, LS1 valve seals, 42.5# injectors, ported sc/intake, custom LS1 TB and MAF, custom FWI, 3.4 mps, NGK TR6, ZZP wires, 180 stat, etc...
  2. #2 Re: well, got the car running after swap, but....
    Charles City, IA
    Yes bare wiring will screw up a lot.
    SMGPFC Two Nipple General
  3. #3 Re: well, got the car running after swap, but....
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    ^^or a bad ground not connected or loose did you make sure u put the 3 grounds on the lower trans housing bolt by the starter ??
  4. #4 Re: well, got the car running after swap, but....
    Dec 2008
    PA
    Well, I unbolted the complete subframe from both cars, and didnt' disconnect any of the wiring from the engine except for the main connection at battery and fuse block. I will sure check that those grounds are there though, thanks.
    Here's a link to my progress.
    Gt to gtp pictures by gotroxblazer - Photobucket
  5. #5 Re: well, got the car running after swap, but....
    Feb 2010
    ohio
    looks real good man
  6. #6 Re: well, got the car running after swap, but....
    Dec 2008
    PA
    ok, I repaired the 5 wires that were chaffed, and that fixed my p1676 code. Still, everything else. I'm going to try the maf sensor from my old engine to see if that helps the other code at all. I'm still confused on the no temp gauge/fan and the gear indicator. I did notice today, that the low oil light will go off then I shift to reverse, then comes on in neutral, and off again in next gear, and so on.... This is racking my brain. I should just take a break from it. I did take it up the road today. I had my scan tool showing 183 degrees. Ran and shifted well, didn't get into it at all though. I still need to have my computer tuned. I'm trying to locate some good wire diagrams for the temp sensor/gauge, and the shift indicator if anyone has access to that? Thanks
  1. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  2. Swap= not running, misfire
    By nxgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2010, 02:11 PM
  3. running hot ??
    By rickchall69 in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-05-2009, 02:55 PM
  4. Got my car running!!!
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 08-02-2009, 01:58 PM
  5. Running Hot
    By 1998xGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-31-2008, 10:41 AM
