Thread: Boost Bypass Valve is forcing boost at idle and reverse.
Results 1 to 11 of 11
  1. #1 Boost Bypass Valve is forcing boost at idle and reverse.
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    So after discovering my BBV had a leak in the bottom, I bought a new one at ZZP for 65$. Replaced it today and I am completely fathomed. When you fist start the car the BBV is OPEN in the up position, seconds after it starts it closes allowing full boost at idle. So for sh**s n giggles i set the e brake put it in drive and its in the UP position or OPEN like its suppose to. But somehow reverse, park, and neutral its closed forcing full boost. whats going on? is it my pcm telling the solenoid to open prematurely?
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  2. #2 Re: Boost Bypass Valve is forcing boost at idle and reverse.
    Wichita
    Did you connect the vacuum lines backwards? ($65 for a BBV?!)
  3. #3 Re: Boost Bypass Valve is forcing boost at idle and reverse.
    Nebraska
    No, im positive they are right I tired reversing them to see what would happen but it did nothing. I meant BBA boost bypass actuator, to get the solenoid mount it was 15 bucks more.
  4. #4 Re: Boost Bypass Valve is forcing boost at idle and reverse.
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Full power in Reverse?
    I vote for a video of reverse donuts before this is fixed.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  5. #5 Re: Boost Bypass Valve is forcing boost at idle and reverse.
    The Boss Iceman6669's Avatar
    Jun 2011
    Second that vote
    2011 F-150 Yote powered
  6. #6 Re: Boost Bypass Valve is forcing boost at idle and reverse.
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Third on that one! To add to that, put in some reverse burnouts! Or maybe even drag in reverse :P just kidding lol
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  7. #7 Re: Boost Bypass Valve is forcing boost at idle and reverse.
    Nebraska
    I dont know about a reverse burnout but if someone can tell me whats going on ill burn sum rubber off on vid and post it lol.
  8. #8 Re: Boost Bypass Valve is forcing boost at idle and reverse.
    dont do reverse donuts, its very bad for the tranny and the axles. then you'll have real problems.
  9. #9 Re: Boost Bypass Valve is forcing boost at idle and reverse.
    Nebraska
    I meant regular burnouts in drive, getting new tires anyways
  10. #10 Re: Boost Bypass Valve is forcing boost at idle and reverse.
  11. #11 Re: Boost Bypass Valve is forcing boost at idle and reverse.
    Newnan, GA
    booooo
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. boost bypass valve
    By 01GrandPrixTURBOGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-23-2012, 09:43 AM
  3. Removing the Boost Bypass Valve?
    By lilrocket in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2012, 02:51 PM
  4. Boost Bypass Valve is it the same as a BOV?
    By xsvtank in forum General Tech Discussion
    Last Post: 08-06-2010, 12:12 PM
  5. Boost Bypass Valve help
    By mikeh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2009, 01:20 AM
