Thread: spark plugs
Results 1 to 4 of 4
  1. #1 spark plugs
    SE Level Member samuelcb409's Avatar
    Galveston, Texas
    decided to change out my plugs after few months maybe 5 months since last and is this normal all 6 looked the same running them on gap .50 i think
    http://farm4.staticflickr.com/3820/9264279151_e3b1bc7df9.jpg
    MODS: 3.0 MPS, CAI, SD Headers w/Custom 3"DP, 160* T-Stat, NGK TR6, Full Size intercooler, #42.5s, Ported LIM & Gen III, LS1 TB w/85mm MAF , s1x Cam, #90 Springs, Intense Pushrods, EGR Delete, Cat and U Bend Delete, Magnaflow Resonator & Mufflers, Fully Built ZZP Trans, 2800 stall Tuned by KHP Peformance
  2. #2 Re: spark plugs
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Holy balls. That's a lot of mods in that sig lol
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  3. #3 Re: spark plugs
    St. Louis
    Hard to tell from the pic, but they look to be a little black, which would lead me to believe that you're running rich, or the plugs aren't the right one's for your setup. Typically a good burning plug would be light tan/brown colored.
    4) Spark Plugs - Change out those stock spark plugs with new ones to restore any lost power. Brands that most tend to go with are either Copper Core Autolites or NGK's. They range as follows in order from hottest to coldest plugs...remember...you want the hottest spark you can get away with...so running a super cold plug on a larger pulley to combat knock isn't the best plan...OEM replacement ACDelco's, AL606's, and AL605's are basically for stock cars or very small bolt-ons still running the stock S/C Pulley or modded N/A guys...you want to keep a hot spark. NGKTR55/AL104's for your 3.4" Setup, TR6's are a tad cooler...best used around the 3.25" pulley area, and AL103's...are for the extreme supercharged application...3.0" pulley or lower. Here is a picture to reference the firing order and the correct coil number if yours aren't numbered or you just need a quick reference picture: http://i33.photobucket.com/albums/d6.../plugwires.jpg
  4. #4 Re: spark plugs
    they look a bit dark. like the dry and wet fouling pic.
  1. Spark plugs?
    By nos4blood70 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-21-2013, 06:26 PM
  2. E3 spark plugs
    By Cartune in forum General Grand Prix Discussion
    Last Post: 08-16-2012, 01:46 PM
  3. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  4. spark plugs
    By gtpdriver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2011, 01:22 PM
  5. spark plugs
    By Nos shottss in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-12-2009, 09:34 PM
