Thread: Replacing coolant temperature sensor
Results 1 to 10 of 10
  1. #1 Replacing coolant temperature sensor
    May 2008
    I need to replace the coolant temperature sensor on my 2000 GTP and was wondering if there is a way to get it off without removing the exhaust pipe next to it. It's sandwiched in there pretty good. I can get the 19mm deep socket on there, but I have no room to actually work it with the ratchet.
    Thanks,
    Steve
  2. #2 Re: Replacing coolant temperature sensor
    Charles City, IA
    Use a wrench.
    SMGPFC Two Nipple General
  3. #3 Re: Replacing coolant temperature sensor
    May 2008
    The wrench is either knocking into the pipe, or the engine block. I don't have any ratcheting wrenches, so I may need to get one to take care of it, if that's the only other way.
    Thanks
  4. #4 Re: Replacing coolant temperature sensor
    Charles City, IA
    Never had to change one. Try a 12pt box end wrench.
  5. #5 Re: Replacing coolant temperature sensor
    Texas
    Were you able to get it off with the ratchet wrench? I'm trying to change the mother****** right now and quite frankly, I'm about to stick a piece of dynamite in the gas tank
  6. #6 Re: Replacing coolant temperature sensor
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    use a swivel socket or just take the crossover off its just 4 bolts
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  7. #7 Re: Replacing coolant temperature sensor
    Dec 2012
    Lowell
    It took me 2 hours to do with a wrench, biggest pain in the a**
  8. #8 Re: Replacing coolant temperature sensor
    I have ratcheting wrenches. It's quicker. Still a pain.
    Now..if we were not talking W body and that stupid dogbone wasn't in the way. You'd have enough room to do it in minutes.
  9. #9 Re: Replacing coolant temperature sensor
    GTX Level Member AKGTP19's Avatar
    Mar 2013
    Fort Lauderdale, FL
    We're can I buy the pigtail for the coolent temp sensor?
    1998 GTP Loudmouth
    1999 GTP, Borla Cat Back.....SOLD
  10. #10 Re: Replacing coolant temperature sensor
    St. Louis
    If you're looking for just the plug then RockAuto has it for $17... More Information for ACDELCO PT1623
    If you need that plus some wire then a junkyard would be my first stop.
  1. Wierd tempature issues after replacing ECT sensor.
    By FlaminWhite97GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2010, 09:24 AM
  2. o-ring for temperature sensor?
    By nlinesk8s in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-04-2010, 04:06 PM
  3. coolant sensor
    By 1LoudGrandPrix in forum General Tech Discussion
    Last Post: 12-30-2009, 07:56 PM
  4. Replacing a speed sensor, where are they located?
    By McCalley08 in forum General Tech Discussion
    Last Post: 01-24-2009, 04:17 AM
  5. Replacing uim and lim 97 gp 3.8 (Coolant Elbows?)
    By Onthebrinc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-13-2008, 05:27 PM
