Thread: bypass solenoid question
Results 1 to 5 of 5
  1. #1 bypass solenoid question
    GTX Level Member Juanmiguel's Avatar
    Mexico
    So I'm still messing with broken vacuum lines on my 98 GTP and I just noticed that the bypass solenoid has 2 vacuum connections on the back and one of them has nothing there, not even a cap. I don't think there's a vacuum leak here. But I wanted to ask you guys what's supposed to be there?
    Pic attached:
  2. #2 Re: bypass solenoid question
    Mexico
    nevermind, i just found another post here in the formus about it. it's supposed to be left opened, i was just miss led by the fact that it had a clamp there and no hose.
    http://www.grandprixforums.net/f81/b...off-22163.html
  3. #3 Re: bypass solenoid question
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    did u take the hose off from the nipple on your throttle body thats partially showing in your picture or did it not have one?
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  4. #4 Re: bypass solenoid question
    Mexico
    Quote Originally Posted by bbptech View Post
    Yes I took it off in order to check the ones in the bypass valve.
  5. #5 Re: bypass solenoid question
  1. Supercharger Bypass Solenoid
    By DPSJosh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-01-2009, 11:28 PM
  2. m90 bypass valve question
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-04-2009, 04:44 PM
  3. bypass the amp...
    By PonchoDvr4Lfe in forum Audio, Security & Visual Electronics
    Last Post: 07-30-2009, 12:07 PM
  4. Boost Bypass Mod????
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2008, 11:04 AM
