Thread: stock pulley.... why am i knocking?
Results 1 to 20 of 26
  1. #1 stock pulley.... why am i knocking?
    Donating Users dirtmaster88's Avatar
    Sheboygan, WI
    Ok I just got my ls1m in the mail today and did my first scan to the car and i'm seeing 5* knock not even at wot. Wtf is going on? Mods below in sig....
    2004 GTP CompG - 3.6" ZZP MPS, K&N CAI, 180* Tstat, SSAC Headers, ZZP Flex, high flow cat, borla exhaust, DHP/danthurs tune, AL104s, ZZP Wires, alt re-wire, slotted/drilled rotors, 35% tint, alpine amp + sub
  2. #2 Re: stock pulley.... why am i knocking?
    in a house
    False knock maybe or your tune is way off.
  3. #3 Re: stock pulley.... why am i knocking?
    Outer Space
    Are your headers hitting your swaybar?
    02 GTP 13.6 @ 100mph - SOLD
  4. #4 Re: stock pulley.... why am i knocking?
    Jan 1970
    Maquoketa, Iowa
    It's pretty typical...
  5. #5 Re: stock pulley.... why am i knocking?
  6. #6 Re: stock pulley.... why am i knocking?
    Oct 2008
    Northern Illinois
    Get a tune and you'll be good.
  7. #7 Re: stock pulley.... why am i knocking?
    Topeka, KS
    You need a tune. One done with tuner hooked up to your car not one you can buy from a vendor placed on a pcm.
  8. #8 Re: stock pulley.... why am i knocking?
    DP + sway bar...had that issue with Ryan's ^^ headers...flip the sway bar upside down and see if it goes away.
  9. #9 Re: stock pulley.... why am i knocking?
    Sheboygan, WI
    I'll look into the DP issue and defiantly get a "real" tune. Thanks guys!
    Edit:
    Being an 04 compg will I have any issues with the sway bar? IIRC the sway bars are different.
    Thanks
  10. #10 Re: stock pulley.... why am i knocking?
    Even if they are different from the 97-03...all your doing is flipping it...so no.
  11. #11 Re: stock pulley.... why am i knocking?
    GTX Level Member killakross5o4's Avatar
    illinois
    get a tune
    Shortstack Intercooler, 1.9 Rockers, 3.2 pulley,180 drilled T stat,103 plugs, U bend delete with no cat, thrush resinator,3inch pace setter cat back,shift kit,ZZP Chrome tips,,ZZP stage 2 throttle body,homemade 4 inch CAI,DHP tuned PCM,SSAC headers
  12. #12 Re: stock pulley.... why am i knocking?
    Topeka, KS
    What is the definition of flipping it. I looked it over Friday when i did the front brakes and didn't quite get it cause i didn't understand what to do or couldn't remember.
    -Ryan
  13. #13 Re: stock pulley.... why am i knocking?
    Banned - Busted For Scamming
    Feb 2009
    They are alot smaller and different design, not a problem.
  14. #14 Re: stock pulley.... why am i knocking?
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    Quote Originally Posted by rynoman03 View Post
    -Ryan
    take your swaybar, unbolt it, flip it upside down, re-attach it.
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  15. #15 Re: stock pulley.... why am i knocking?
    SE Level Member geforcextreme's Avatar
    Holland Pa 18966
    When my buddies bone stock 05 comp g was on the dyno, I saw 7KR. These cars do get KR stock and its pretty bad.
    2000 Buick Regal GSE Blown, Cammed, Intercooled, and pretty fast for a Grocery Getter - 320WHP
    Best Time June 9th 2009: 1/4 = 12.994 @ 107.82mph on Street Tires 2.118 60 Foot
  16. #16 Re: stock pulley.... why am i knocking?
    Sheboygan, WI
    btw I looked at the sway bar and it's pretty far from the headers. I did notice that the front o2 sensor was tight up against the firewall, could that be the issue? My cars got 83k on it so i'd like to replace it soon anyways. Do they make shorter o2 sensors?
  17. #17 Re: stock pulley.... why am i knocking?
    no, bang on the firewall with a mallet.
    83K miles is old?
  18. #18 Re: stock pulley.... why am i knocking?
    83K miles is old?
    this.
  19. #19 Re: stock pulley.... why am i knocking?
    Sheboygan, WI
    sweet. a bfh is my favorite tool
    83k isn't old but isn't 100k the recommended time to replace it? Also getting a crappy 15 mpg right now which is another reason to replace it.
  20. #20 Re: stock pulley.... why am i knocking?
    what are you talking about replacing?
    and 15 MPG means either something is seriously wrong or you're in the gas way too much.
    edit: oh the O2 sensor, it should be good for quite a while. Apparently they're over-replaced.
  1. 3.5 pulley with stock pcm and K&N CAI
    By mac507 in forum General Tech Discussion
    Last Post: 01-28-2010, 11:55 AM
  2. Rattling/Knocking Coming from Pulley/Belt Area
    By pc305577 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2009, 09:32 PM
  3. Can I run a 3.4 pulley on a stock gtp?
    By darkhorizon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 11:25 AM
