Thread: Noise at bout 2000-2500 RPM
Results 1 to 20 of 32
  1. #1 Re: Noise at bout 2000-2500 RPM
    Charles City, IA
    no it checks bearing clearances.
    SMGPFC Two Nipple General
  2. #2 Re: Noise at bout 2000-2500 RPM
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    thats what i ment my bad
  3. #3 Re: Noise at bout 2000-2500 RPM
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    think the problem might be figured out. took the front cover off again, and the bolts to my machined pump cover show wear marks on them from the chain. obviously because i put 1 metal timing cover gasket on it. picked up 2 paper gaskets today to space it out somemore. We will see what happens tomorrow when the motor goes back in and gets started. on the rear header, cylinder 6 showed a slight exhaust leak.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  1. Distributor O-Ring leak. $2500!?
    By rw53104 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 08-20-2011, 06:52 AM
  2. We have passed 2500 Members
    Last Post: 11-26-2008, 08:31 AM
  3. 2500 Bucks
    By jacobmh27 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-12-2008, 12:48 PM
