I recently picked up a 2004 Grand Prix GTP, very nice clean car and got a nice deal on it. Loaded to the hilt, every option. Got one issue with it though. Under full boost it chokes, I can get it up to 7psi and it will jump between 4-7 psi at full throttle but does not feel like it has the power it should, almost feels like its choking. I have checked all vacuum lines and replaced all of them, all intake gaskets are new. Has a K&N intake on it and all is connected right there. Fuel pressure holds the same at full throttle as at idle, around 60 psi.
Also at full throttle it has a whining noise comming from under the hood, not what I am used to considering this is like my 10th L67 car, not the aftermarket intake making noise either.
Im stumped and Im a mechanic for a living. I have a OTC Genisys scanner and have had it hooked up to the car and checked every reading and nothing seems out of the ordinary, so im at a loss now.
