Thread: Problem With BBV
Results 1 to 3 of 3
  1. #1 Problem With BBV
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Hey guys. I just received my SS M90 kit, and I noticed that the plastic tabs holding the boost bypass valve actuator to the bracket have broken off. The actuator is loose and not secured. What can I do to fix this? Do I need a whole new piece? I've heard if you take it off, it messes with the alignment of it, and the valve won't function properly. I attached a few pictures to explain what happened. Thanks.
  2. #2 Re: Problem With BBV
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Epoxy it? I don't think there's anything special about those tabs, as long as you get it secured, you should be fine.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: Problem With BBV
    Quote Originally Posted by Scimmia View Post
    Actually nevermind, Zoomer from ZZP emailed me and he will send me a new one right now. Thanks Scimmia!
  1. HID Problem
    By Dthreap in forum Audio, Security & Visual Electronics
    Last Post: 11-16-2009, 05:05 PM
  2. Anyone else have this problem?
    By PMave in forum Audio, Security & Visual Electronics
    Last Post: 10-04-2009, 08:09 PM
  3. MAF problem or is it something else?
    By apdale in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2009, 06:00 PM
  4. HUD problem
    By the1euge in forum General Tech Discussion
    Last Post: 08-31-2009, 12:23 PM
  5. Replies: 6
    Last Post: 02-07-2009, 01:16 AM
