Thread: pulley puller
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #1 Re: pulley puller
    SE Level Member NineD9GT's Avatar
    Dec 2008
    PA
    Ok, so I made my pulley puller. I prob. WAY over engineered it. I made it out of 1/2" plate steel. It has 4 perimeter bolts (5/16") For the center bolt, I used a standard puller bolt that had a hole in the center. I TIG welded an 8 mm stud to the end of it. I made a "bearing plate" out of a used bearing and a washer. I'll take pics. and load them. I won't get to try it till this weekend. I hope the 1/2" plate isn't too thick to fit behind the pulley, as I built this with the supercharger elsewhere. Think I'll be ok?
    99 GP GT L26 bottom end, Intense stage II cam, Ported L67 heads w/ LS6 springs, LS1 valve seals, 42.5# injectors, ported sc/intake, custom LS1 TB and MAF, custom FWI, 3.4 mps, NGK TR6, ZZP wires, 180 stat, etc...
  2. #2 Re: pulley puller
    Banned - Busted For Scamming
    Feb 2009
    Hopefully 1/2" is thick enough not to bend. I originally used 3/8" steel and it bent like tin foil. My second design (above) is now 1" aluminum.
  3. #3 Re: pulley puller
    Dec 2008
    PA
    wow, what size are your four little bolts? 5/16-3/8? I can't see this thing bending... but, like I said, I never took one of these off. I honestly had to sit and think about how it was going to work.
  4. #4 Re: pulley puller
    Feb 2009
    In the above post they are 3/8". That pic is not the current design, i added more bolts to the top section so that firmed it up quite a bit.
    It takes 6 tons of pressure to remove the pulley btw.
  5. #5 Re: pulley puller
    Hmm...I heard it was 10,000 pounds of pressure...or 5 tons...but who knows.
  6. #6 Re: pulley puller
    Dec 2008
    PA
    either way, that's alot. I guess this bearing idea should work pretty good then. Does it go on that hard?
  7. #7 Re: pulley puller
    Feb 2009
    No the new pulley goes on easy. Just put some anti seize on there.
  8. #8 Re: pulley puller
    Wichita, KS
    ^lube your shaft up before sliding it on in other words.
    ~F~
  1. pulley puller
    By iquick4 in forum General Tech Discussion
    Last Post: 04-13-2009, 07:01 AM
