Thread: timing Chain
Results 1 to 6 of 6
Zach3800 timing Chain 02-21-2010, 09:28 PM
TheOtherNick Re: timing Chain 02-21-2010, 09:30 PM
Zach3800 Re: timing Chain 02-21-2010, 09:39 PM
TheOtherNick Re: timing Chain 02-21-2010, 09:41 PM
blueguy Re: timing Chain 02-21-2010, 11:01 PM
1bad3800 Re: timing Chain 02-21-2010, 11:12 PM
  1. #1 timing Chain
    SE Level Member Zach3800's Avatar
    Waterloo IL
    Well i had a JP double roler in my car and it snapped the chain friday night. Im trying to fiqure out if I should put another JP in a rollmaster? looking for info on which is better
    All you need to know is High compression big a$$ Cam plus blower
  2. #2 Re: timing Chain
    Charles City, IA
    Rollmaster. From what I have herd they have a far better record. Also get the crank gear machined.
    SMGPFC Two Nipple General
  3. #3 Re: timing Chain
    Waterloo IL
    how much needs to be machined off
  4. #4 Re: timing Chain
    Charles City, IA
    Best way is to take a stock crank gear in and have them match the double roller to it
  5. #5 Re: timing Chain
    ^^Exactly...replied to your post on KCPMC too.
    I have a Rollmaster Double Roller and had the gear machined down to the same height as the stock one.
  6. #6 Re: timing Chain
    SE Level Member 1bad3800's Avatar
    Jan 2009
    bensalem pa
    you gotta buy a matched set dunt mix match it will not wor the pitch of the gears are different i have brand new roll master chane i am looking 2 sell or jp. gears all split them up i am looking 2 get rid of one of them if your intrested ..
  1. timing chain
    By pure in forum General Tech Discussion
    Last Post: 08-16-2009, 02:00 PM
  2. What's up with the timing chain issues
    By joesforspeed in forum Turbo
    Last Post: 07-02-2009, 09:47 PM
  3. Which timing chain to get.
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2008, 09:01 AM
  4. Which timing chain?
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2008, 04:49 PM
