Thread: Project Z38. Fosho99/Nvsridez Build
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 92
  1. #21 Re: Project Z38. Fosho99/Nvsridez Build
  2. #22 Re: Project Z38. Fosho99/Nvsridez Build
    GT Level Member hourang's Avatar
    commerce, mi
    nice project. subscribe.
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  3. #23 Re: Project Z38. Fosho99/Nvsridez Build
    Donating Users nvsridez's Avatar
    sw WI
    Last nights progress; Blower bolted on, radiator installed, motor mount bolt holes tapped, fuel rails test fitted, Lil Caesars devoured.
  4. #24 Re: Project Z38. Fosho99/Nvsridez Build
    Quote Originally Posted by nvsridez View Post
    Last nights progress; Lil Caesars devoured
    THIS is where in the f*ck its at!
  5. #25 Re: Project Z38. Fosho99/Nvsridez Build
    commerce, mi
    no jets is wheres its at! lil ceasars cardboard crap.
    -Jeff
  6. #26 Re: Project Z38. Fosho99/Nvsridez Build
    Becca Boo MizzBecca's Avatar
    Michigan
    Sub'd bc I can't imagine McLovin doin' any kind of work
    I drive a POS
  7. #27 Re: Project Z38. Fosho99/Nvsridez Build
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by MiZzBeCcA View Post
    Sorry you can't keep me out of your imagination. Why don't you drink some goldslick vodka and go fuck Evan you penis drawing hater!
  8. #28 Re: Project Z38. Fosho99/Nvsridez Build
    Donating Users blowfishRus6's Avatar
    g.a.
    hahaha
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  9. #29 Re: Project Z38. Fosho99/Nvsridez Build
    sw WI
    Sunday progress:
    Radiator fans installed properly, throttle hooked up, pulley/belt installed, vacuum lines installed, wire tuck on bcm wires, made alternator pretty, and after 1 year of it on jack stands, it's back on the ground. Also, we cleaned his garage. It was the largest task thus far.
  10. #30 Re: Project Z38. Fosho99/Nvsridez Build
    g.a.
    sweet!! looks like its coming together good!
    its slow.
  11. #31 Re: Project Z38. Fosho99/Nvsridez Build
    Looks like theres less weight on the wheels.
    Suspension work still need to be done?
    Still awesome though.
  12. #32 Re: Project Z38. Fosho99/Nvsridez Build
    commerce, mi
    soo badazz. get some wiring in that bish and start it!
    -Jeff
  13. #33 Re: Project Z38. Fosho99/Nvsridez Build
    Michigan
    Quote Originally Posted by FoSHO99 View Post
    LMFAO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!
    I drive a POS
  14. #34 Re: Project Z38. Fosho99/Nvsridez Build
    sw WI
    The car has drop springs in it, but the suspension had no weight on it for a year, so I'm assuming once the vehicle has sat a week or so, then driven, it will drop even more. Although, the subframe if only 6 inches off the ground now......
  15. #35 Re: Project Z38. Fosho99/Nvsridez Build
    sw WI
    Quote Originally Posted by hourang View Post
    We're waiting on the wiring harness from Brian Teel. Hopefully within 2 weeks we should have it.
  16. #36 Re: Project Z38. Fosho99/Nvsridez Build
    fair enough, good luck and keep us updated!
  17. #37 Re: Project Z38. Fosho99/Nvsridez Build
    GTP Level Member
    Nov 2008
    MA
    how much are you estimating the vehicle to weigh once its all said and done? def an interesting build, good job
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  18. #38 Re: Project Z38. Fosho99/Nvsridez Build
    Jan 1970
    Maquoketa, Iowa
    Probably a few #s more than stock, but now will have 270-300whp.
  19. #39 Re: Project Z38. Fosho99/Nvsridez Build
    memphis
    Great build
  20. #40 Re: Project Z38. Fosho99/Nvsridez Build
    SE Level Member Lumina Z38's Avatar
    Dubuque
    this is my ride
  1. The new guy: Matto's Project build thread!
    By Matto211 in forum General Tech Discussion
    Last Post: 01-10-2009, 07:47 PM
