Well Lets Pray that i don't need the injectors quite yet.
So now i got another question. The only nozzles that came with my kit were M15 and are way too big. These are also the inside mount type nozzles. Hopefully the outside mount nozzle will mate up to my tb spacer and i could just use the pre-existing hole. Or I could tap the TB it's self.
Should i go ahead and convert to the outside mount nozzles and be done with it? Also i noticed that my pump doesn't have the quick disconnects for the lines. I'm guessing i could get those from devils own as well ?
I have noticed that on some peoples installs they have used these quick connects as seen here.... http://www.alcohol-injection.com/90-...itting-28.html
Do these make installs alot easier and where do you get the tubing? Just at a local parts store or is it special...?
Last question... My Pump did not come with a mount is this something you all have been fabing up or do they usually have a mount attached to them. There are two small threaded areas on the back of the pump looking like something used to be there.
As Always TIA!
-Ryan
