I recently fixed a leaking hose that i assumed was cusing all my overheating issues. I filled it with coolant, and it ran like normal for the first day. the next day, it started acting like it wanted to over heat (temp hand was everywhere) but i drove it home anyway. it stayed @ a constant temp of 210 to 235 degrees. The following day, i get in it to drive off and the low coolant light comes on (the third time over the past few weeks) and i check the radiator, no coolant. Its bone dry but there is no coolant on the ground and none in the oil pan. Wtf man? You think it's a blown gasket (head or intake)? I am gonna pressure test it this weekend but if i find the pressure leaking, how much does it normally cost to fix this? i've heard it can be retardedly expensive....
