Thread: Blown head gasket?
Results 1 to 9 of 9
  1. #1 Blown head gasket?
    Georgia
    I recently fixed a leaking hose that i assumed was cusing all my overheating issues. I filled it with coolant, and it ran like normal for the first day. the next day, it started acting like it wanted to over heat (temp hand was everywhere) but i drove it home anyway. it stayed @ a constant temp of 210 to 235 degrees. The following day, i get in it to drive off and the low coolant light comes on (the third time over the past few weeks) and i check the radiator, no coolant. Its bone dry but there is no coolant on the ground and none in the oil pan. Wtf man? You think it's a blown gasket (head or intake)? I am gonna pressure test it this weekend but if i find the pressure leaking, how much does it normally cost to fix this? i've heard it can be retardedly expensive....
  2. #2 Re: Blown head gasket?
    check your oil. if there is coolant in your oil you have bigger problems than losing your coolant because you might end up losing your motor too.
  3. #3 Re: Blown head gasket?
    Georgia
    i said there was none in the oil pan man.
  4. #4 Re: Blown head gasket?
    can you see it leaking externally anywhere? no coolant on the ground? white smoke out the exhaust?
  5. #5 Re: Blown head gasket?
    Georgia
    if there is any leak on the outside or out of the exhaust, its tiny and takes a day or two of running to look out such a large amount of coolant.
  6. #6 Re: Blown head gasket?
    Georgia
    leak*
  7. #7 Re: Blown head gasket?
    Nov 2008
    norman oklahoma
    lower intake failing , your motor is next, if not already, fix ur lim gasket. read . use the stickies in the forum
  8. #8 Re: Blown head gasket?
    Guamuchil Sinaloa Mexico
    In these types of engines is a failure very common and i have a 95 percent of security that are the head gasket, but also have to carry the head to give surface to a specialized workshop
  9. #9 Re: Blown head gasket?
    Oct 2008
    Northern Illinois
    Could be a leaking LIM
  1. low, very low oil. blown head gasket or something else?
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 01-04-2010, 03:51 PM
  2. 98 gtp bad head gasket
    By nscottp in forum Off Topic Discussion
    Last Post: 09-07-2009, 12:40 AM
  3. blown head gasket
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-09-2009, 12:18 AM
  4. Possible Blown Head Gasket
    By Blk99GpGt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-09-2009, 12:40 PM
