Thread: stripped snout threads, no pulley on right now!!
Results 1 to 19 of 19
  1. #1 Re: stripped snout threads, no pulley on right now!!
    SE Level Member thomasj's Avatar
    Indiana
    Sounds like you got it, but If you ever have a have a machine shop press a pulley on be SURE they dont press on it without the shaft supported. The support should be on the center of the shaft were the coupler hooks up. If they press it on without the shaft supported it can push the shaft down in the housing or damage the bearings. All of the support needs to be on the shaft as if the snout housing was not even there.
    If I were you Id get an MPS so you never have to do this again.
  2. #2 Re: stripped snout threads, no pulley on right now!!
    South Dakota
    Quote Originally Posted by thomasj View Post
    i totally agree. Dont let the press- on tempt you with the lower price haha i know money can be tight. ive pressed on two different pulleys on my car and one on someone elses with that damn tool and it seems like something ALWAYS goes wrong, drop the little Effin washer, strip the snout, strip one of the bolts, receive an all ready damaged tool, the list goes on.
    3.4 pulley, Wizaired intake, 3" catless dp, 160* tstat, Shortened dogbones, Ported manifolds, aftermarket mufflers, 103's, zzp pcm
  1. Transmissoin pan bolt stripped
    By 99prixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-06-2008, 10:39 PM
  2. Alternative fix for stripped threads
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2008, 05:03 PM
  3. how to write ups and comments threads
    By Toasty in forum Forum Bugs/Suggestions
    Last Post: 01-24-2008, 09:51 AM
