Thread: Low Fuel Pressure on first start up. HELP!!
Results 1 to 11 of 11
  1. #1 Re: Low Fuel Pressure on first start up. HELP!!
    Charles City, IA
    No. Just try adjusting the regulator either way and see what the pressure does. Is it an aftermarket pump? Did you rewire the pump? If so check the voltage at the pump.
    SMGPFC Two Nipple General
  2. #2 Re: Low Fuel Pressure on first start up. HELP!!
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    We tried adjusting the pump. No change. Voltage to pump is right. Has an aftermarket pump and has the rewire done.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  1. Fuel Pressure Regulator Help
    By Latdogg in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2009, 03:43 PM
  2. WOT fuel pressure
    By Sabrewings in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-05-2009, 12:38 AM
  3. fuel pressure gauge
    By gtchris in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2009, 02:43 PM
  4. Fuel Pressure
    By RedGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2008, 10:53 PM
  5. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
