I noticed a significant increase in throttle response. As far as compatibility, I'm pretty sure the WizAired has a version that works with Series III motors. Contact ZZP and ask.
That makes no sense given the math.
CAI_Primer_ThermalFrom this curve, the intake air temperature significantly influences the horsepower output of an engine. For example, if an engine's intake temperature was dropped from 110°F to 75°F, then the change is horsepower is approximately +7% ( -1% @ 75°F minus -8% @ 110°F). If the engine normally produces 200 horsepower, then this 7% increase in power translates to about a 14 horsepower increase. Achieving the lowest possible intake temperatures is therefore very advantageous.
And 110*F is very generous to the cooler side of the temp of the air being sucked in by a open cone on a hot day with the fans running. Probably more like 150+*F. But, given the 110*F, and that it's 70*F so the CAI is probably getting 75*F air after a little heatsoak on its way in, you're saying that alone, the removal of the restriction caused by the intake tube will net you more than a 14HP increase (on a stock L36)? It just doesn't follow with what we know already.
Just referring to non-intercooled cars, by the way. But, the more power you're making, the greater HP to be had by cooling the intake charge. The engine is not losing 14-15HP because of the intake tube (let's be realistic here), so your statement is not supported.
I prefer a discussion based on facts, so if you have proof I'm very interested to see it.
