Thread: Driving with the ECT Sensor Disconnected
Results 1 to 11 of 11
  1. #1 Re: Driving with the ECT Sensor Disconnected
    SE Level Member FlaminWhite97GTP's Avatar
    Nov 2009
    Monee, IL
    Quote Originally Posted by FoSHO99 View Post
    There are quite a few tables in the pcm that run off of the ECT, some of them being AFR. No ECT would definitely cause all of those problems...
    Yea that what I thought, I read up on it & I didn't know this sensor control everything because if it shows no tempature everything wont run right.
    Quote Originally Posted by Rather B Blown View Post
    how is it gonna fry your pcm if you plug it in?
    Well I looked at the ECT Sensor to try to see if I could connect it, but It looked like the black cover was missing off the tip of the sensor & all I saw was 3 long prongs. So I said F*ck it, I didn't wanna short the PCM out until it was time for me to upgrade it. The mechanic was a great guy & had cheap prices (He's also an ex GTP tuner), but IMO I think he probably broke it when he was replacing the LIM Gaskets. He said he would replace it for $40 total with the sensor, but he like an hour from me & I dont have the time to go out that far.
    Can anybody give me instruction on how to replace this sensor myself, I would great appreciate it
    176K Miles, Things Done: 25K Tranny, VC & LIM Gaskets Replaced, synthetic fluids all around.
    Mods to come: CAI, Headers, Roller Rockers, U-bend & DP Delete, etc
  2. #2 Re: Driving with the ECT Sensor Disconnected
    PA
    Quote Originally Posted by FlaminWhite97GTP View Post
    If he just got done doing the LIM gaskets, then yes, I would say he broke it. It is not necessary to take the sensor out to change the gaskets. But if you are not careful when you remove the LIM, you can easily break the sensor. So I would put my money on him breaking it.
    But changing it is very easy. Buy the sensor. Put a little thread sealant on the new sensor. Remove the old one. Put in the new one quick. You shouldn't loose too much coolant, but check it and fill if necessary after a couple days.
    2001 GSE
  3. #3 Re: Driving with the ECT Sensor Disconnected
    Nov 2009
    Monee, IL
    Quote Originally Posted by Zef_66 View Post
    Ok I just bought the sensor today. I see where the old sensor is, but it looks to be in a cramped spot at a wierd angle. Zef do you know the quickest & easiest way to get to the sensor & what tools to use.
  1. vibration when driving around
    By littlerobinson75 in forum Brakes/Suspension/Chassis
    Last Post: 08-23-2010, 09:26 PM
  2. Driving a car when its too cold
    By Haulero in forum General Tech Discussion
    Last Post: 01-12-2010, 02:22 PM
  3. Winter Driving
    By 07GXP4Me in forum 5.3L V8 (LS4)
    Last Post: 11-17-2009, 10:05 PM
  4. This is driving skill!
    By Abrasive in forum Off Topic Discussion
    Last Post: 11-14-2008, 11:02 PM
  5. while driving, BOC!
    By fst in forum The Rant Forum
    Last Post: 02-04-2008, 10:47 AM
