TheRealKoop
Ive never seen an application on any car that opened the bypass once the turbo was spooled. Most of the time people just cram the air through the rotors, as spinning rotors are less restrictive then your dime sized bypass valve. Its a good idea though. But running a small pulley then opening the valve would still cause alot of parasitic loss from spinning the blower so fast.
I would probably just run a large pulley like a 3.4(4 psi) or 3.2(6psi), depending on how much lowend grunt i wanted, and then turn the turbo up accordingly.
