Thread: How do i change/add oil to my supercharger, and what oil type do i use?
Results 1 to 20 of 23
  1. #1 How do i change/add oil to my supercharger, and what oil type do i use?
    St. Joseph, MO
    I recently bought a Grand Prix GTP, and i was wondering how to check/change/add oil in my Supercharger? plz help me out.. thanx.
  2. #2 Re: How do i change/add oil to my supercharger, and what oil type do i use?
    Charles City, IA
    There is a hex plug in the snout. You have to take it out and suck the old fluid out and then replace it with new fluid. Buy the gm supercharger oil from a dealership.
    SMGPFC Two Nipple General
  3. #3 Re: How do i change/add oil to my supercharger, and what oil type do i use?
    St. Joseph, MO
    ok, thank you!
  4. #4 Re: How do i change/add oil to my supercharger, and what oil type do i use?
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    dont be surprised if it smells like straight up @$$.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  5. #5 Re: How do i change/add oil to my supercharger, and what oil type do i use?
    GT Level Member Joe m's Avatar
    mesa,az
    make sure you buy 2 bottles if your getting it from the dealer. cuz they jew you and only sell like 7.5 ounces in a bottle and if i remember right you need more then that.
  6. #6 Re: How do i change/add oil to my supercharger, and what oil type do i use?
    Donating Users kfish's Avatar
    Ohio
    i just bought zzp's oil. it comes in the right amount.
  7. #7 Re: How do i change/add oil to my supercharger, and what oil type do i use?
    Apr 2009
    stockton ca
    use a spray bottle sprayer to suck it out the stuff will smell like a$$ and dead hookers on a hot day its funky stuff
  8. #8 Re: How do i change/add oil to my supercharger, and what oil type do i use?
    GTX Level Member JoelW98GTP's Avatar
    Nov 2009
    Portsmouth, OH
    Quote Originally Posted by wickedintent79 View Post
    ^^^^ This is a perfect explanation of how it smells!
    98 GTP - Autolite 104s, wires, 180* t-stat, fwi, catless dp and plog, glasspack res, Reptile tuned PCM, tinted tails.
    91 Toyota MR2 Turbo - 327RWHP 322RWTQ 11.48@122mph
    03 BMW 325i - tint. stock.
  9. #9 Re: How do i change/add oil to my supercharger, and what oil type do i use?
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    when you fill it up, it should come to the bottom of the threads
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  10. #10 Re: How do i change/add oil to my supercharger, and what oil type do i use?
    SE Level Member BlackGS's Avatar
    Central Jersey
    I got a small turkey baster like this, then attached about 6-8" of clear tubing to the end with some tape. I can get about 90% or more of the supercharger oil out that way.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  11. #11 Re: How do i change/add oil to my supercharger, and what oil type do i use?
    PA
    Quote Originally Posted by BlackGS View Post
    Same. Turkey baster was from wal-mart. I attached a piece of black vacuum hose with a hose clamp. In fact, the wife came out to the garage and wanted to borrow it the other day.
    2001 GSE
  12. #12 Re: How do i change/add oil to my supercharger, and what oil type do i use?
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    ^^^^i thought it was just me!!. is the s/c coupler ok? just trying to avoid extra work later
  13. #13 Re: How do i change/add oil to my supercharger, and what oil type do i use?
    Wichita, KS
    When warm (after you drive it for a while) let it cool down some, and remove the allen head/hex head plug from the snout. Make sure you use the correct size allen wrench so you don't strip out the head of the plug.
    I am the creator of the syringe sucker, and have used this method for many years, even before I owned my GTP. Works awesome.
    Insert hose into snout, pull back sucking all the old oil out. You have to do this about 3 or 4 times to get it all. I will put the used oil in a old bottle with a screw lit that seals it inside. I will dispose of this oil, with my regular engine oil.
    Using 2 bottles of GM oil, refill. The fluid level should come to the bottom of the threads of the plug. (flash light helps to see this sometimes)
    2 bottles is all you need, nothing more or less. GM some times will under fill, as well as over fill many of these bottles, as long as its to the bottom of the threads, you will be alright. I have NEVER needed more than 2 bottles of the GM oil per supercharger.
    Reinstall plug, CAREFUL not to cross thread it into the soft aluminum. Also, now is a good time to check the condition of the o-ring on the plug, making sure its still round, and pliable. If its flat, dry, and cracked, might look into a new replacement. I replace these with a Viton replacement. Part number for that is 012-75 for future reference.
    ~F~
  14. #14 Re: How do i change/add oil to my supercharger, and what oil type do i use?
    Dec 2008
    hueytown, alabama
    awesome pix and write up, good job.
  15. #15 Re: How do i change/add oil to my supercharger, and what oil type do i use?
    Nov 2009
    South Carolina
    I just changed mine.It is simple but I called 3 dealerships in my area and none had the oil.Balwin buick in Laurens SC did tell me to use a 5w30 synthetic.I went with royal purple.They could order the oil for me but I had to order a case and he said I didn't want to know how much.My supercharger is much quieter now.
  16. #16 Re: How do i change/add oil to my supercharger, and what oil type do i use?
    PA
    Quote Originally Posted by sparkles View Post
    FWIW, this has been widely debated in other forums. A couple have used synthetic fluid, but it is really not recommended, and has never been extensively tested. The GM supercharger fluid is apparently used because of it's ability to not foam and cavitate when running at 15k+ RPMS. Synthetic engine oil does not have these same properties and the cavitation can cause excessive wear problems on your gears. I understand you wanted to change the fluid, but I would try to get the correct fluid in there ASAP before too much damage is done.
    2001 GSE
  17. #17 Re: How do i change/add oil to my supercharger, and what oil type do i use?
    Jul 2008
    sumter,south carolina
    off topic... sparkles..what part of SC are u from? im in sumter.
    02 GTP with mods 05 GP for DD
  18. #18 Re: How do i change/add oil to my supercharger, and what oil type do i use?
    Nov 2009
    South Carolina
    Thanks I am planning on changing it again soon to clean it out.I will try to get the recommended oil but I went to 3 dealerships and the last one recommended any 5w30 synthetic.Thats why I used it.IDK but none had it in stock and the Chevy dealer in laurens didn't even seem to know what I wanted.(They said they didn't deal with pontiac anymore try someone else!?!) Sometimes I think they are jerks because I am a female and guys in my area think we shouldn't play with boy toys.LOL.As far as where I am located,I am in the Lake Greenwood area!
  19. #19 Re: How do i change/add oil to my supercharger, and what oil type do i use?
    Its a buick engine... That also appeared in chevy's as well...
    Ask your local dealership to order it in for you.
  20. #20 Re: How do i change/add oil to my supercharger, and what oil type do i use?
    Wichita, KS
    12345982 is the GM supercharger oil part number.
    If the dealer does not stock it, they CAN order it no problem. It comes to them in a box of 12, but they CAN open the box and sell you it by the bottle.
    GM List is around $10.17 a bottle. Usually costs you about $7.50 a bottle. I get mine for about $5.50 a bottle, but I buy it by the case, and multiple cases at a time, = discount. Prices change on the stuff, up or down all the time.
    Once year I will order my SC oil, and drop a couple hundred bucks on just that. My GM parts guy always says, I bet GM is scratching their heads and wondering what this Kansas dealership is doing with all this oil. LOL
    ~F~
  1. Supercharger fluid change 01 gtp
    By brownb66 in forum General Tech Discussion
    Last Post: 11-19-2009, 07:41 AM
  2. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
  3. what type of charger is this?
    By gtchris in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2009, 07:54 AM
  4. 04 RSX type-s
    By 99prixgt in forum Track Sessions and Kills
    Last Post: 12-08-2008, 10:05 PM
  5. What type of retainers do I have?
    By 1998gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2008, 04:16 PM
