Thread: school me on my 180* Tstat
Results 1 to 14 of 14
  1. #1 school me on my 180* Tstat
    SE Level Member mxthunder's Avatar
    NE Ohio
    Ok, my car has a 180* Tstat in it, as well as a digital HP stage 1 pcm.
    Is there a traditional style thermostat that makes the car run cooler, or is the "180* stat" just telling the computer to kick the fans on sooner?
    Its 10*F here in ohio, and I can here my radiator fans kicking on constantly, and my needle is barely off the peg, makes no sense to me.
    I am getting a check engine light because the coolant temp is "below the threshold" and I cant pass an e-check until I get this fixed, and I am now on my last temporary tag, lol, I have 1 week to get it to pass.
    Thanks
    Autolite 103 plugs, PRJ 8 gauge wires, 160* drilled tstat, Digital Horse Power Stage 1 PCM, Voltage booster harness, 3.25" pully, ZZP S.S. IC, Desert Fox tranny cooler/Thrasher shift kit, Wizair CAI, SLP headers/full system wrapped & coated, 3 gauge pods: A/F, Boost (16.5 lbs), comp G. 17" 04 GTP rims
  2. #2 Re: school me on my 180* Tstat
    Apr 2009
    stockton ca
    The 180 tstat opens at 180* allowing the car to run cooler the fans kick on due to programing in the pcm that tells them to kick on at 180* its all about helping a modded car run cooler
    As for your problem no clue i havent had any issues with that code or a check engine light due to the temp
  3. #3 Re: school me on my 180* Tstat
    Donating Users blowfishRus6's Avatar
    g.a.
    180 thermo opens at 180* and allows coolent to flow thru. you can try putting the stock 195* thermo back in.
    ive resently raised my fan settings back up, i was tired of waiting forever for the car to get up to operating temps. plus the heat
    dident work as good then :/
    you can try putting the stock thermo back in, but the fans are still gonna run when there supposed to be turned on (its in the tune, you can adjust at what coolent temp the fans come) or you can find someone with a tuner to adjust when the fans come on.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  4. #4 Re: school me on my 180* Tstat
    GTX Level Member JoelW98GTP's Avatar
    Nov 2009
    Portsmouth, OH
    Quote Originally Posted by mxthunder View Post
    Thanks
    The ECU/fans/t-stat all work together to keep the engine at the desired level. the t-stat is mechanical and will begin to open up once the coolant reaches 180*. The PCM will tell the fans to kick on for additional cooling. The fans are controlled by the PCM. The stock PCM is set to kick the fans on at the factory setting of 195-197*. The DHP PCM can be programmed to kick the fans on at 180* to work with the lower temp t-stat. I have the same setup you have and my temp gauge sits middle ways between 160* and the first large mark. I'm not sure about your DTC. Never seen that one. Maybe someone here knows more about that part of it. Try having a local parts store clear SES codes if you don't have a scanner and give it a couple days and see if the SES comes back on. Might just be a one time error. It happens.
    98 GTP - Autolite 104s, wires, 180* t-stat, fwi, catless dp and plog, glasspack res, Reptile tuned PCM, tinted tails.
    91 Toyota MR2 Turbo - 327RWHP 322RWTQ 11.48@122mph
    03 BMW 325i - tint. stock.
  5. #5 Re: school me on my 180* Tstat
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by blowfishRus6 View Post
    ive resently raised my fan settings back up, i was tired of waiting forever for the car to get up to operating temps. plus the heat dident work as good then :/
    The car would get up to operating temps faster with the lower thermostat.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  6. #6 Re: school me on my 180* Tstat
    NE Ohio
    Ha yes, but they would be 'lower operating temps'
    Yeah, I have cleared out the codes but they come back in a few days. The light will actually shut off by itself if I let it go long enough.
    I will probably just pickup a stock Tstat from autozone and throw it in to help my emissions for the test, since ive already failed twice, then put the 180* back in after so I dont kill my fans.
    Thanks for the education!
  7. #7 Re: school me on my 180* Tstat
    Nov 2009
    Portsmouth, OH
    good choice! hope you pass!
  8. #8 Re: school me on my 180* Tstat
    g.a.
    Quote Originally Posted by JoshMcMadMac View Post
    no it would not. and i never said that. if your reffering to my set up, im running the stock thermo.........
    i know you like to scroll the forums looking to tell people there wrong, and never give back positive feed back, but not today
    its slow.
  9. #9 Re: school me on my 180* Tstat
    Waynesboro, PA
    I give help where I can, when someone else has not gotten to it.
    So, your car gets to 195 faster than it gets to 180?
  10. #10 Re: school me on my 180* Tstat
    Donating Users kfish's Avatar
    Ohio
    why are you getting an emissions test in ohio? i never have
  11. #11 Re: school me on my 180* Tstat
    g.a.
    ahh, okay i see what your getting at. i miss read. my bad.
    to me, operating temps is not 180, its as close to 200 or above as i can get. i dont care to run a cooler block, there is not much benifets from it. that and a value my heat, the heater core is ran off the coolent, i like to keep the coolent going into that as high as possible.
    the reason my car was taking so long to get up to operating temps is because i had the fan setting turned on before the t stat would open and it wasent really helping. i would pretty much have to drive my car to get it up to the temps i wanted it, thus cranking the car up and sitting there waiting for the heat to get hot was not happening.
    yes it would get up to 180 faster than 195.
    its slow.
  12. #12 Re: school me on my 180* Tstat
    Waynesboro, PA
    Ah ha! Very cool, thank you for the clarification...we had a mis-communication on the term "operating temperature. Time from start-up to 180°, faster; time from start up to 200°, much slower. I do understand your issue with running fans sooner, as well.
  13. #13 Re: school me on my 180* Tstat
    NE Ohio
    Quote Originally Posted by kfish View Post
    We are one of the lucky 6 or 7 counties that have to get it.....
    Just to update you all, I passed my echeck with a few bottles of rubbing alcohol and dry gas in the tank with about 3 gallons of gas. She ran great, and passed with flying colors!!!
    and yes... I diluted it out immediately after the test with a full tank of gas
  14. #14 Re: school me on my 180* Tstat
    g.a.
    never heard of passing like that.
    good to hear you passed.
    its slow.
  1. 180 tstat
    By bballa0740 in forum General Tech Discussion
    Last Post: 10-03-2009, 08:31 AM
  2. Drilling a Tstat????
    By WHT98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2009, 06:49 PM
  3. 180 tstat question
    By superv6 in forum General Tech Discussion
    Last Post: 04-17-2009, 12:25 PM
  4. School
    By Wadeb79 in forum Off Topic Discussion
    Last Post: 01-13-2009, 02:05 PM
  5. 180 degree Tstat
    By bula81069 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2008, 02:05 PM
