Thread: Stutters when floored
Results 1 to 20 of 28
1000PRIX Stutters when floored 01-07-2010, 12:05 AM
blueguy Re: Stutters when floored 01-07-2010, 12:58 AM
Ibwrong Re: Stutters when floored 01-07-2010, 07:10 AM
badbrad Re: Stutters when floored 01-07-2010, 08:07 AM
GR8racingfool Re: Stutters when floored 01-07-2010, 02:34 PM
BADAZGTP Re: Stutters when floored 01-07-2010, 09:04 PM
JoelW98GTP Re: Stutters when floored 01-07-2010, 09:09 PM
BADAZGTP Re: Stutters when floored 01-07-2010, 09:23 PM
JoelW98GTP Re: Stutters when floored 01-07-2010, 09:35 PM
Ibwrong Re: Stutters when floored 01-08-2010, 07:44 PM
BADAZGTP Re: Stutters when floored 01-07-2010, 09:53 PM
1000PRIX Re: Stutters when floored 01-08-2010, 07:11 PM
badbrad Re: Stutters when floored 01-09-2010, 01:34 AM
David F Re: Stutters when floored 01-12-2010, 12:08 PM
GTPluv Re: Stutters when floored 01-12-2010, 01:54 PM
Juanmiguel Re: Stutters when floored 01-12-2010, 05:10 PM
1000PRIX Re: Stutters when floored 01-14-2010, 05:33 PM
alkygto Re: Stutters when floored 01-15-2010, 01:16 PM
matt5112 Re: Stutters when floored 01-15-2010, 01:40 PM
badbrad Re: Stutters when floored 01-15-2010, 02:49 PM
alkygto Re: Stutters when floored 01-15-2010, 04:37 PM
alkygto Re: Stutters when floored 01-15-2010, 05:16 PM
matt5112 Re: Stutters when floored 01-15-2010, 04:55 PM
alkygto Re: Stutters when floored 01-15-2010, 05:25 PM
JoelW98GTP Re: Stutters when floored 01-16-2010, 12:56 AM
kamamm Re: Stutters when floored 01-16-2010, 01:09 AM
alkygto Re: Stutters when floored 01-16-2010, 03:23 PM
matt5112 Re: Stutters when floored 01-16-2010, 08:17 PM
  1. #1 Stutters when floored
    Canada
    K guys so I just had the, LIM, TB, SC gasket, Fuel pump, Crankshaft Positioning Sensor replaced and did a tune up (plugs, wires, new gas, injector cleaner, air filter, coolant flush and fill)
    Now the car is not stuttering as bad as it was before this but still stutters when I punch it....If I gradually accelerate its fine its only when I punch it
    This all seemed to start after I had my down pipe replaced and a hole in the exhaust fixed so Im not sure if it has anything to do with that
    Any ideas guys???
  2. #2 Re: Stutters when floored
    Any CEL/SES?
    I'd say coils/ICM
  3. #3 Re: Stutters when floored
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Just had the same issue the other day and it was a plug wire, so I would say since you already replace them its probably like blue said coils or ICM
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  4. #4 Re: Stutters when floored
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    in ur hayne s or chilton manual, it'll tell u how to check the resistance in the primary and secondary side of the coil. advance or autozone can check the icm i believe.
  5. #5 Re: Stutters when floored
    Wichita, KS
    Check and make sure the correct plug wire is on the correct coil, and matching plug. Easy to get one crossed if your not paying attention. Follow each wire from the coil, and make sure it goes to the right plug. Many times, people will get them switched on the back, commonly #2 and #4.
    You have a mis fire most likely.
    ~F~
  6. #6 Re: Stutters when floored
    Apr 2008
    Chillin at the Beach , VA
    Had the same issue with mine a while back and it was a coil bad. A test you can do is, start with unplugging your #1 plug, go for a quick drive, if it gets worse, put that one back on and do the #2. Keep going until you unplug a wire that doesn't change what it's doing. It'll help pin point which plug, wire, or coil is giving you problems. Just remember to keep the wire you unplug away from moving parts and if you unplug from the coil side to try and fing some type of rubber cap to go over it so you don't risk arching.
  7. #7 Re: Stutters when floored
    GTX Level Member JoelW98GTP's Avatar
    Nov 2009
    Portsmouth, OH
    Quote Originally Posted by BADAZGTP View Post
    His car runs fine until he punches it. If he takes loose a plug wire, it's gonna run like crap all the time. This will prove nothing.
    98 GTP - Autolite 104s, wires, 180* t-stat, fwi, catless dp and plog, glasspack res, Reptile tuned PCM, tinted tails.
    91 Toyota MR2 Turbo - 327RWHP 322RWTQ 11.48@122mph
    03 BMW 325i - tint. stock.
  8. #8 Re: Stutters when floored
    Apr 2008
    Quote Originally Posted by JoelW98GTP View Post
    Yeah your right. I over thought that one. Been a long day. A weak coil would give him that problem. A bad one would cause it to run like crap even at idle. Thanks for smacking me in the back of the head for that one.LOL!!!!!
  9. #9 Re: Stutters when floored
    Nov 2009
    Portsmouth, OH
    GR8racingfool is off on the same path too! lol. I wasn't smacking you in the head , just trying to keep this guy from possibly getting confused.
    I'm with bluegtp91 though, prolly a coil or ICM. Coils fixed my rough idle......thanks sean! lol
  10. #10 Re: Stutters when floored
    Oklahoma City
    I have to comment on this.. My #1 plug wire was loose from some stuff we did with chances car one night and the car ran fine until I had any kind of boost then it fell on its face and would only ever get up to half boost.. Fixed that and shes back up and running.
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  11. #11 Re: Stutters when floored
    Apr 2008
    Yeah, I had a random stalling issue, and that turned out to be my ICM. When I had a coil go, I had the same issue he is having. as long as your easy on the gas and drive normal, it's fine, but, as soon as you hav to merge into traffic or take off a little too hard, she'd stutter her butt off.
  12. #12 Re: Stutters when floored
    Canada
    If I have a bad or failing coil would I still get spark because I get spark at every plug....You guys dont think it has anything to do with the exhaust like not enough getting out in time tyoe thing....BTW thank you all so much for your quick responses
  13. #13 Re: Stutters when floored
    Dec 2008
    hueytown, alabama
    is your car running right yet? what have u found?
  14. #14 Re: Stutters when floored
    Tecumseh, Mi
    My car does the same thing and I have been told it could be the fuel filter or a Cat! ( I'm not throwing any codes at all! ) Anybody agree or disagree? PLEASE HELP!!!!!
  15. #15 Re: Stutters when floored
    GTP Level Member GTPluv's Avatar
    Enid,Ok
    Mine has been acting like that for more than a year. I've changed all of my coils. Is the ICM what the coils set on? (im a girl) If so, I've had it checked, and it's good. mine dont act up all the time, just whenever. have a new fuel filter and 02 sensor also. now no codes thrown
    good luck 1000PRIX
  16. #16 Re: Stutters when floored
    GTX Level Member Juanmiguel's Avatar
    Mexico
    Mine was kind of doing something like that, one time I opened the hood at night and even though the spark plug wires were new, the heat insulators were jumping a small spark to the manifold and I removed them.
    This only happened to me at full throtle and high RPM tho...
  17. #17 Re: Stutters when floored
    Canada
    Ya Juanmiguel mine only happens at full throttle or high RPM also.....I still have not found the problem any other ideas guys ??
  18. #18 Re: Stutters when floored
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    Same problem here. Car was running fine but I had an injector lock up, bought a new one to replace it and had them all cleaned and flow checked. Before I narrowed it to the injector ( Code was miss on cyl 6) I replaced the plugs with NGK TR6's gapped at .035, wires with packard wires, and replaced all 3 coils with the Summit coils. It runs fine at part throttle ( up to 3/4 throttle it is a rocket ) but full throttle it feels like it is stuttering. I am not sure if it is ignition or fuel, no codes. Oh, and the car is a 1997 GTP 2 door. Mods are SLP catback, Thrasher CAI, 160 thermo, aftermarket PCM, 3.4 pulley, ported blower. Everything ran fine until injector problem. I would like to put some headers on next but I need to get this straightened out.
  19. #19 Re: Stutters when floored
    Quote Originally Posted by alkygto View Post
    Actually putting those headers on would make your car run safer. Right now you're probably knocking quite a bit.
  20. #20 Re: Stutters when floored
    Dec 2008
    hueytown, alabama
    i put i think msd wires(got them on clearace at advance) long boots. no more glowing ring around plugs...do easy stuff like fuel filter, gotta check for cat operation..new denso(my choice) o2 sensor, make sure u didn't break ceramic around plugs(i have),good wires, check coils, and auto store should be able to check icm.....i think thats it, my head hurts.
  1. Car Hesitates When Floored
    By 04GTPeeingOnU in forum General Tech Discussion
    Last Post: 07-14-2009, 07:05 AM
  2. *HELP*car stutters and feels like misfiring above 50% throttle
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2009, 01:47 AM
