Thread: Normal Running Temperature
Results 1 to 10 of 10
gorps Normal Running Temperature 01-15-2010, 02:12 AM
Rather B Blown Re: Normal Running Temperature 01-15-2010, 02:44 AM
Bio248 Re: Normal Running Temperature 01-15-2010, 12:39 PM
Rather B Blown Re: Normal Running Temperature 01-16-2010, 07:51 PM
Zef_66 Re: Normal Running Temperature 01-16-2010, 09:06 PM
a98gtp4u Re: Normal Running Temperature 01-15-2010, 08:02 AM
TorqueAutoMotiv Re: Normal Running Temperature 01-15-2010, 10:40 AM
gorps Re: Normal Running Temperature 01-16-2010, 09:33 AM
a98gtp4u Re: Normal Running Temperature 01-16-2010, 10:24 AM
kfish Re: Normal Running Temperature 01-16-2010, 12:23 PM
  1. #1 Normal Running Temperature
    SE Level Member gorps's Avatar
    Ontario
    I'm curious to know the normal running temperature for a 2000 GTP. On the gauge, it will barely make it past 80 C (about 185 F), even if I have been driving for an hour or more. I've only notice it increase when the engine was warm and I was idling for 5 mins or so.
    My Low Coolant light is on but there is plenty of fluid in the rad and reservoir and the test on the mixture temperature is fine. The warning light use to go off after about 5 mins of running (once the engine was warm it wouldn't come on) but now it is on all the time. Another question, can having too much fluid in the reservoir be a bad thing?
    Any thoughts?
    Thanks,
    Dan
  2. #2 Re: Normal Running Temperature
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    mine never goes more than a quarter of the way up the gauge, like 80-85 degrees. Thats just how GPs are i think, cause every one ive been in is the same. As for the coolant light, your sensor is probably just dirty, take it off and clean it up see if that helps.
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  3. #3 Re: Normal Running Temperature
    Quote Originally Posted by Rather B Blown View Post
    1/4 up the gauge is in the 180-190* area. the gauge pretty much starts at 160*.
    with a 180* thermostat youll run in the 190-195* area. with a 195* thermostat youll run in the 205-210* area.
  4. #4 Re: Normal Running Temperature
    Dec 2008
    London, Ontario
    im from canada so mines in degrees celcius, same as the op, so i figured it would be easier if i explained it that way instead of in degrees fairenheit
  5. #5 Re: Normal Running Temperature
    PA
    I think you just need to understand how inaccurate the dash gauge is. If I read my temp with a scanner, it reads right where it should around 190-195°F (with 195° stat). But the dash gauge reads 160-170°. Nothing to worry about or anything you can fix. Just something to understand and live with.
    2001 GSE
  6. #6 Re: Normal Running Temperature
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    oem thermostat should be 195*.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  7. #7 Re: Normal Running Temperature
    Apr 2009
    stockton ca
    mine used to run at around 200-210 in summer little cooler in winter
    ur thermostat could be a 185 someone else put in how long have you had the car
  8. #8 Re: Normal Running Temperature
    Ontario
    WOW! Thanks for all the great info guys.
    PS: I bought the car in Sept '09.
  9. #9 Re: Normal Running Temperature
    GEORGIA
    btw, the low coolant sensor is crap. my light n the dash would flicker off and on, even when it was full of coolant, so i replaced the sensor and still did it with the new 1. i ended up just removing the light out of the cluster.
  10. #10 Re: Normal Running Temperature
    Donating Users kfish's Avatar
    Ohio
    ^haha yep. screw the idiot lights :P
  1. Temperature Problems
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-19-2010, 10:55 AM
  2. What is the normal engine temperature?
    By noname in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-14-2010, 07:37 PM
  3. Temperature Actuator
    By s7falcon in forum Shops and Community Heroes
    Last Post: 09-04-2009, 11:36 AM
  4. Engine Temperature Normal Range...
    By Chris in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2009, 08:17 AM
  5. right temperature to put on overlays?
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 02-08-2009, 01:33 PM
