Thread: Rocker install
Results 1 to 9 of 9
  1. #1 Rocker install
    SE Level Member mikesarebetter's Avatar
    Spearfish, sd
    ok, i tried searching this forum but the search tool sucks here. i was going to install some 1.9's but that kinda fell thru for the moment.
    question is when you torque down your new rockers doesn't the cylinder your working on have to be at TDC? me and a buddy were goin back and forth on this cuz i'm almost 100 percent you can't be in the middle of a stroke when tightening them down.
    all who know please enlighten
    2003 GTP, pacesetter headers, colder plugs, zzp pcm for now, CAI, 3.5 pulley and 180tstat
  2. #2 Re: Rocker install
    GTX Level Member cerick08GP's Avatar
    http://www.grandprixforums.net/lim_lifter_video.php
    If you’re also replacing the springs, with 1.9s you better, placing the cylinder at/near TDC will keep the valve from falling into the engine. I believe that is the only reason people move the crank around, but I’m not sure if this is even relevant to 3800s. I know someone will add to this, good luck man.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: Rocker install
    Nope...done rockers on a couple cars...just unbolt the stockers and throw the new ones on. Can you do it? Sure...is it worth it...prolly not. I would just prime it and then crank it over for a minute or so with the VC's off and the ICM unplugged to see if everything moves correctly...then re-torque everything to make sure they are all snugged down to what they are supposed to be...and IIRC that is like 25 ft.lbs or something close to that. While your there...I'd put in reusable bolts from Comp.
    Then take it out and be easy on it to see if everything sounds good and if it does...give it hell That way you'll know for sure if something is bad or not LOL
  4. #4 Re: Rocker install
    Jersey
    When i was tightening the new ones, i would crank the motor by hand, then check torque readings, repeat, repeat, repeat, until all them are torqued in any motion.
    16' wrx sti- stock
  5. #5 Re: Rocker install
    Donating Users kfish's Avatar
    Ohio
    i thought the rocker torque spec was 11ft/lbs. maybe im on crack.
  6. #6 Re: Rocker install
    Charles City, IA
    the stock tty are 11ftlbs +90* reusable ones are like 25ftlbs.
    SMGPFC Two Nipple General
  7. #7 Re: Rocker install
    GT Level Member shawn3091's Avatar
    Jan 2009
    State College PA
    23ft/ibs for comp reusable bolts, right off of zzp's site, I just put the modded 1.9s on mine a few days ago, very easy to do. Havent driven it yet, its not coming out of garage until summer
  8. #8 Re: Rocker install
    Donating Users blowfishRus6's Avatar
    g.a.
    i just torqued my down how it was. no issuies.
    how i see it, you are torqueing a bolt into the head, not the actual rocker down. i had to short of pushrods at first for my slp 1.8 rockers and when torqued down the dident even hit the pushrods. just kinda goes to show your not torqueing the rocker down to the push rods and valve springs. only the bolt into the head.
    priming them up tho is not a bad idea.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  9. #9 Re: Rocker install
    Banned - Busted For Scamming
    Feb 2009
    To do it properly and right, you have to take it to tdc (valves closed) to alleviate the pressure from the lifters pushing against the rockers via the pushrod. You have to do this to get an accurate torque and yes it is 11 ft/lbs plus 90 Degrees.
  1. ?1.9 rocker question?
    By mikesarebetter in forum General Tech Discussion
    Last Post: 11-09-2009, 08:45 PM
  2. best rocker bolts
    By 2000gtp1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2009, 11:18 AM
  3. rocker panels
    By The1AndOnlyBug in forum 5.3L V8 (LS4)
    Last Post: 07-22-2009, 08:07 AM
  4. Total lift after rocker install.Question
    By TDCRacing in forum General Tech Discussion
    Last Post: 12-06-2008, 04:03 PM
  5. 1.9 modded rocker install
    By ExpyGator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 12:38 PM
