You need to be comfortable with tuning to make the switch. A wideband is a must, as well as larger injectors then fuel pump rewire and possibly better fuel pump depending on what you are seeing from tuning. It initially takes 30-40% additional fueling and tune it from there. You will lose some mpg, but you will see very good gains as far as hp.
