Thread: Fuel Pump or Filter?
Results 1 to 4 of 4
  1. #1 Fuel Pump or Filter?
    Michigan
    I have a 1997 Grand Prix with a 3800 supercharger engine.Was driving and the car just died. Hooked a gauge to check the fuel pump preesure and upon start up it read 40-50 psi and then the pressure slowly starts to drop and finally the cars stalls. I bought the car used and was told by the owner that he changed the fuel pump but the fuel filter was not brought up, so my question is should I change the filter first before the pump? And also is there a way to do a check out of the pump? And what about the resistors and relays I been reading about whats a good way to check those out?
  2. #2 Re: Fuel Pump or Filter?
    Largo, Florida, United States
    Flagged for Wrong Section.
  3. #3 Re: Fuel Pump or Filter?
    Arizona
    fuel filters are cheap, replace that first then go for the Big $$$$$ items next. Cances are that when the first pump was replaced it stirred up crud in the tankand got pumped to an already clogged filter. The slowly reducing pressure means eaither a bad pump or the filter gets clogged as it runs choking off the flow. Good luck
  4. #4 Re: Fuel Pump or Filter?
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    put a $10 filter on, then check ur problems.
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Oil Pump/Filter Assembly
    By Randomx in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2009, 04:25 PM
  3. fuel filter.........
    By julian2875 in forum General Tech Discussion
    Last Post: 07-21-2009, 12:48 PM
  4. S.O.B. Fuel Filter
    By quiksilvergt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2008, 01:16 PM
