Thread: Maybe I FINALLY found the problem..?
Results 1 to 10 of 10
  1. #1 Maybe I FINALLY found the problem..?
    Oct 2008
    Northern Illinois
    Well after troubleshooting every little thing trying to figure out why my gas mileage blows and my idle is so rough, and the performance has been lacking a bit too, the car finally threw a code a couple days ago for a bad catalyst. All these things are symptoms of a clogged cat right? Maybe the thing will finally run normal again. I'm thinking about picking up the magnaflow high-flow cat from ZZP, cuz it's actually cheaper than the oem replacement from rockauto, and a friend is giving me his 3" DP. Hopefully that'll clear up these issues, and probably kill some KR too.
  2. #2 Re: Maybe I FINALLY found the problem..?
    Jul 2008
    sumter,south carolina
    what the code? could be bad 02 sensor... if a friend is giving u a 3" dp unless its catless... why would u need another cat?
    02 GTP with mods 05 GP for DD
  3. #3 Re: Maybe I FINALLY found the problem..?
    Banned
    Warner Robins AFB
    Why didn't you post asking for help with this problem ahead of time, that's a very obvious problem and would of saved you a lot of time and trouble diagnosing it.
  4. #4 Re: Maybe I FINALLY found the problem..?
    Oct 2008
    Northern Illinois
    Quote Originally Posted by Iroquois Pliskin View Post
    I did, many times. But there were alot of other things that are fixed now could have been causing the problem, so it was hard for anyone to put their finger on just the cat. EXCEPT I'm pretty sure I remember BIO months ago said "I bet months from now when your done fixing all this crap you're just going to have a clogged cat, and then I'm going to laugh at you". Guess who was right But whatever, all the other things needed to be fixed at some point anyway so I don't mind.
  5. #5 Re: Maybe I FINALLY found the problem..?
    Oct 2008
    Northern Illinois
    Yeah it's catless but I want a cat. It threw a code for catalyst not functioning optimally. Don't remember the exact code.
  6. #6 Re: Maybe I FINALLY found the problem..?
    he has a few times already. we have been trying to diagnose his car for quite some time (since he top swapped it, actually).
  7. #7 Re: Maybe I FINALLY found the problem..?
    Banned
    Warner Robins AFB
    Quote Originally Posted by BwolfGT View Post
    All I have to say in reply to this is Bio wins, rest of the forum fails. Exclude me because I didn't see the previous threads.
  8. #8 Re: Maybe I FINALLY found the problem..?
    eventually he will have it fixed and it will run like a good running top swapped car (fast).
  9. #9 Re: Maybe I FINALLY found the problem..?
    IMO...just take the cat out...beat all the crap out of it and have it welded into the 3" DP your getting...or just run it catless...and find someone to inspect it for you when the time comes.
    Rest of the forum fails. Exclude me because I didn't see the previous threads.
    I'm INcluding you for your arrogance. Way to knock everyone else that has tried to help him in the past.
  10. #10 Re: Maybe I FINALLY found the problem..?
    Oct 2008
    Northern Illinois
    Yeah seriously dude, these people have been helping diagnose this forever. And thanks to them there were a TON of issues that I didn't even know were there that got fixed, that would've eventually caused some major problems in the future. Thanks to everyone on this forum that's been helping me out, especially blue and bio. After this I just need a new coolant overflow tank cuzmine's cracked and hopefully I'll be good.
  1. Sunroof still leaks...FOUND PROBLEM FINALLY
    By 99prixgt in forum General Tech Discussion
    Last Post: 05-19-2011, 09:52 AM
  2. Think I might Of Finally Found A New Car
    Last Post: 11-22-2008, 10:16 AM
  3. I finally found a home!
    By spank127 in forum Introductions/Noob Questions
    Last Post: 06-23-2008, 01:27 AM
  4. Finally found my vac leak... NOW WHAT??
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-07-2008, 02:32 PM
  5. I finally found this place.
    By sra_chipmunk in forum Introductions/Noob Questions
    Last Post: 01-01-2008, 07:31 PM
