Thread: First Modification
Page 8 of 8 FirstFirst ... 678
Results 141 to 154 of 154
  1. #141 Re: First Modification
    Spit on them...it works.
  2. #142 Re: First Modification
    GT Level Member hourang's Avatar
    commerce, mi
    swwweeet, so i found in intake piece i had left over from my 98 camaro ss. its an according style about 4in long, about 4in on one end and 3.5 on the other. hooked that on the tbody and the 3in filter fit in the 3.5in side. soo much better. i can actually hear the blower now.
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  3. #143 Re: First Modification
    Donating Users blowfishRus6's Avatar
    g.a.
    Quote Originally Posted by hourang View Post
    thats the whole reason for getting an intake
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  4. #144 Re: First Modification
    GTX Level Member Juanmiguel's Avatar
    Mexico
    Ok so I've got the Ubend delete in place, the 180tstat and the cold air intake, the engine is running fairly cooler now and better I think. Should I be switching to cooler spark plugs now or is it too soon? I know that those would lower the KR with enough mods, but I don't know if those could actually have a negative effect without the right mods in place.
  5. #145 Re: First Modification
    commerce, mi
    oh btw op i seem to have picked up some mpg too if i dont hammer on it. this is solely going off the dic though which im not sure is accurate. oh and my old filter was caked in dirt, so probably not a good test anyhow.
    -Jeff
  6. #146 Re: First Modification
    Keep the stock heat range plug until you drop a pulley size. You always want the hottest spark possible...so get some Autolite 605's.
  7. #147 Re: First Modification
    Mexico
    Thanks Blue I don't know where would I be without your advice guys haha. With those few mods I can notice difference on the performance already I've been smoking fart cans and other stuff all week haha. I'm renaming the perf shift button to "humiliation mode" once I drop pulley size.
    Before I mess up my next mod (3" DP), I'd like to avoid starting the "Fail Down Pipe vX" series, so I'll ask for advice in advance. I'm planning to get one done at the shop with 3" tube from the collector to the CAT inlet. Basically following the stock shape of the tube, I assume the purpose of this mod is putting in a thicker width and not changing the shape of it right?
    Also, should I also consider changing the stock CAT for a high flow one? I'm only planning on dropping to 3.4" pulley.
  8. #148 Re: First Modification
    'performance shift' does nothing if you tune your transmission to always have higher line pressure and shift points.
  9. #149 Re: First Modification
    Mexico
    Yeah I'm not sure if the PCM tune will eliminate the use of that button. I guess it depends on the tune company, but I won't be doing it myself for now, that's for sure, I don't have enough knowledge to change that without messing it up.
    I normally drive with the perf shift off. how about you?
  10. #150 Re: First Modification
    g.a.
    yea i think an aftermarked down pipe follows the same shape as the stock downpipe. pretty much you wanna make it 3in from the rear manifold where it bolts up, all the way to the resinator.
    its slow.
  11. #151 Re: First Modification
    commerce, mi
    Quote Originally Posted by blowfishRus6 View Post
    not when it comes to the ubend area, you want that straight with the o2 off the side instead of up.
    -Jeff
  12. #152 Re: First Modification
    g.a.
    well yea dont add the u bend into the new downpipe :P
    its slow.
  13. #153 Re: First Modification
    Mexico
    yeah hehe. I already did the Ubend a few days back, but it's 2.5" I did it that way since the resonator inlet was 2.5". The part that I will do now is only from the manifold to the CAT inlet, that one will be 3" for sure.
  14. #154 Re: First Modification
    Just get rid of the cat and make it 3"...then reduce it at the rezzy.
  1. New To GP Owners! Looking For Modification & Performance Sites
    By quickgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-23-2009, 11:03 PM
  2. modification update re: exhaust modifications
    By 02BlueGTP in forum General Tech Discussion
    Last Post: 04-29-2009, 12:31 PM
  3. Venturi modification of Walbro 255LPH
    By Lysander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2009, 01:49 PM
  4. LIM Modification
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2008, 09:20 PM
  5. Modification Page
    By webracin in forum Site/Club News
    Last Post: 12-14-2007, 03:38 PM
