Thread: cam
Results 1 to 20 of 36
  1. #1 cam
    GT Level Member grand2000prixgtp's Avatar
    Grayslake
    what cam will give me the most power but not give me a bad idle. i was looking at the xp or intense-racing stage 2or 3.
    2000 GTP silver four door, K&N cone filter, autolite 104 plugs, slp cat back, 3.4 pulley, zzp pcm, pacesetter headers, zzp stage 1 throttle body, ported superchrger, F body brakes. sold...
    2004 GTO all stock for now.
  2. #2 Re: cam
    Well if your looking a stage 3 then your going to get a pretty rough idle. Light baby idle is the VS...then the S1X, XP, S2X...
    I ran a XP daily for over a year and had no issues.
  3. #3 Re: cam
    Grayslake
    ok i was thinking the xp. will stock heads work with that cam?
  4. #4 Re: cam
    yes. xp is a stock heads cam, but if youre looking at that cam i would go with an s1x instead. much better cam for proven power. this would be the cam i would choose for stock heads.
    although im a firm believer that a cam on stock heads is pretty useless, so yeah..
  5. #5 Re: cam
    Grayslake
    alright. and one more thing im planing on building an engine with the cam and i was wondering should i get the n/a engine and build that or get the supercharger one?
  6. #6 Re: cam
    get the higher compression block if youre sticking with an m90 build.
  7. #7 Re: cam
    Grayslake
    alright. with the internals be able to handle the supercharger?
  8. #8 Re: cam
    yes. knock is knock. you can blow away an l67 just as easy as an l36. if its not knocking then youll be fine, you just have to be aware that with the higher compression youre more prone to knocking on less boost.
  9. #9 Re: cam
    Grayslake
    alright thanks
  10. #10 Re: cam
    Grayslake
    im not sure if it will work but will a v6 camaro engine work in our cars?
  11. #11 Re: cam
    GT pistons are also weaker...IMO they are WAY easier to pop then a L67...but I have yet to test that theory since all I've blown up are L67's.
  12. #12 Re: cam
    prove it.
  13. #13 Re: cam
    You ever looked at one side to side? That tells you right there...the skirts are thinner, piston tops are thinner...I'd be willing to bet it is 20 times weaker than a L67.
  14. #14 Re: cam
    Donating Users blowfishRus6's Avatar
    g.a.
    well zzps 500hp+ car has a stock gt bottom end if that means anything
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  15. #15 Re: cam
    if it doesnt knock then you have nothing to worry about.
  16. #16 Re: cam
    Grayslake
    a series III will bolt right up in to a 2000 right?
  17. #17 Re: cam
    Charles City, IA
    You talking about the bottom end? Then yes. The whole engine no. They are drive by wire.
    SMGPFC Two Nipple General
  18. #18 Re: cam
    Grayslake
    ok thanks
  19. #19 Re: cam
    Grayslake
    is there any aftermarket pistons that aren't like $900
  20. #20 Re: cam
    nope, but why would you need them? are you pushing a ton of power? doubtful.
cam
