Thread: Coolant levels
Results 1 to 2 of 2
  1. #1 Coolant levels
    GT Level Member Xorbex's Avatar
    Canada
    Just wondering where the coolant level should be when I open the rad cap on my 2005 gtp. I opened the cap today to do a test on the coolant and noticed that I could not see any coolant in the rad. I do have about half full resivoir. Also just to let you guys know the car had been shut off for about 20 minutes before checking the level. It was at operating temp. The heat works fine and I have no service lights on. Is this normal??? Also I noticed some orangish gunk near the top of the rad cap. Is this bad and what steps should I take to correct this if it's bad.
    Merry X-Mas
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  2. #2 Re: Coolant levels
    Charles City, IA
    Should be full to the top of the rad. You should get it flushed out to clean out all that gunk.
    SMGPFC Two Nipple General
  1. Coolant
    By kaiser0427 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2009, 08:03 AM
  2. coolant ?
    By 04GTP in forum Off Topic Discussion
    Last Post: 06-24-2008, 09:42 AM
  3. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
  4. How much coolant?
    By chitownchevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:30 AM
  5. what is the difference between member levels.
    By s1795so2 in forum Off Topic Discussion
    Last Post: 01-11-2008, 06:05 AM
