Thread: best air intake
Results 1 to 20 of 21
  1. #1
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    wow I can't believe someone lit this wick so soon.
    Just know that a properly installed CAI gives you the cold air of a fwi and a shorter distance for the air to travel like an open cone.
    Downside to a CAI - price and the room a box takes up
    Downside to an open cone - heated air intake, moreso on a daily driver.
    Downside to a fwi - long way for the air to travel and the filter is exposed to more dirt and some have said water.
    I run an AEM driflow filter and wouldn't use anything else.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    Quote Originally Posted by IndeedSS View Post
    I don't want to beat the dead CAI horse anymore than it already has been. But from personal experience - with both Thrasher and MSP air boxes - my temps were 10-12* above ambient, pretty steadily - when I installed my FWI - my temps were 3-4* above ambient - at worst.
    I think if you're going to have an intake - and it's intended to pull in the coolest air possible - then you should pull it from as low to the ground as possible. That being said - yes - you will have more maintenance (filter cleaning) than with a stock or CAI box, but it's worth it to get the gains. As for water entering the intake - not likely, unless one drives through excessively high water - like, over the wheels. In that case - they will likely have other issues than hydro lock to contend with.
    With a FWI - yes there is a longer distance for the air to travel, but it's also coming in at a greater volume.
    In the end - it's your car; your choice - do want you want.
    Indeed - Where did you get your dry flow filter? I'm interested in running one, but don't know much about them.
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  1. Make A 4" Fenderwell Intake (FWI)[*]
    By Street Wolf in forum How To Write-Ups/Tech Tips
    Last Post: 05-17-2019, 05:23 PM
