Thread: Should I do the XP Cam or Stage 2 Intercooler??
Results 1 to 20 of 22
  1. #1 Should I do the XP Cam or Stage 2 Intercooler??
    Indiana
    i have an 02 gtp with ssac headers, 3.4", stage 1 tb, k&n cai, dhp pcm, plugs etc.. i'm thinking about either doing the ZZP XP Cam or the Stage 2 Intercooler kit from WBodyStore. Which would you suggest? I live in Central Indiana, near Indianapolis so i dont know i could get a tune at? Should i do cam or intercooler? which would make more power? where could i get a tune at close by Indianapolis Indiana? all thoughts and help appreciated.
  2. #2 Re: Should I do the XP Cam or Stage 2 Intercooler??
    Portland Oregon
    Both will help kill KR so you can run more timing. The cam will change how the motor breathes. I would cam it first before an intercooler. That way you get the most of the motor work out of the way and the intercooler you can just plumb the lines later on and slap it on the intake. While you have the motor apart it would be wise to get a machined lower intake and the blower ported to match an intercooler so you could just slap it on there at a later date.
  3. #3 Re: Should I do the XP Cam or Stage 2 Intercooler??
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    I say both as well.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  4. #4 Re: Should I do the XP Cam or Stage 2 Intercooler??
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    You have to decide how far you want to take the car, and what you want the end result to be...that will dictate the best choice.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  5. #5 Re: Should I do the XP Cam or Stage 2 Intercooler??
    First off...I'd get the cam and supporting mods...I.E. Springs/Retainers. Then, I'd get injectors with the IC. That way you'll be able to keep dropping pulley sizes and not have to worry about a lean issue like I did or the injectors running static. Since you already have headers you have the exhaust side taken care of...now get the cam done. Tuning? Trannyman95...or Dave. He is in Fort Wayne and owns Triple Edge Performance. He does great work and if you are going to be doing all these mods you might want to keep him in mind for transmission work too...especially if you plan on running it in the 1/4.
  6. #6 Re: Should I do the XP Cam or Stage 2 Intercooler??
    Indiana
    How about doing the VS cam and getting a machined lower intake then getting the blower p&p to match, then ordering a Northstar throttle body and getting the inlet on the blower p&p to match, then injectors?
  7. #7 Re: Should I do the XP Cam or Stage 2 Intercooler??
    because...a VS cam is weak. Not that the XP is great but it is a way better cam than a VS
  8. #8 Re: Should I do the XP Cam or Stage 2 Intercooler??
    you still havent expressed how fast you want to go with this car or how much money you want to spend. should we start there, please?
  9. #9 Re: Should I do the XP Cam or Stage 2 Intercooler??
    SE Level Member 2001GTP's Avatar
    Apr 2009
    Phoenix, AZ
    PRJ Performance is located right outside of Indy. Morristown I think it is. Probably one of the best tuners around. Welcome to PRJ.Performance
    3.6", 3" Downpipe, K&N CAI, 104's, PRJ Tune, P-Log, 180 t-stat,Res delete, wideband, boost gauge. 14.11" @ 99.5
  10. #10 Re: Should I do the XP Cam or Stage 2 Intercooler??
    Indiana
    I'm looking to spend around a 800 to a 1000 on just parts. I know i would need more for stage 2 intercooler but thats what i have now
  11. #11 Re: Should I do the XP Cam or Stage 2 Intercooler??
    Donating Users kfish's Avatar
    Ohio
    paul at prj is about 20 miles outside of indy. you could get ahold of him and see how much hed charge for a tune. mine was 90 bucks. www.prjperformance.com
  12. #12 Re: Should I do the XP Cam or Stage 2 Intercooler??
    Apr 2009
    Phoenix, AZ
    Quote Originally Posted by kfish View Post
    Last time I was there he told me he was changing his rates to $60 for the first hour and $30 for each additional hour. Funny thing is I was there for 5 hours tuning and he charged me $75. I also bought him lunch at Hardee's though.
  13. #13 Re: Should I do the XP Cam or Stage 2 Intercooler??
    Donating Users blowfishRus6's Avatar
    g.a.
    man...
    first of allllllll diffrent cams have diffrent power bands. the vs is a nice midrange cam while the xp is more of a topend cam, but makes more power. you also lose gas milage with a cam.
    a fullsize intercooler car is probably almost just as fast as an xp cam set up car.
    what are you looking for???
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  14. #14 Re: Should I do the XP Cam or Stage 2 Intercooler??
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    If it were me, I'd intercooler 1st
    Pro's
    Better gas milage
    Safer than cam
    less valvetrain wear
    if you demod you don't have to go into engine
    No potential timing chain issues
    The list goes on and on.
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  15. #15 Re: Should I do the XP Cam or Stage 2 Intercooler??
    Quote Originally Posted by blowfishRus6 View Post
    False. It is in the tune. I still saw around or over 30 mpg's with my XP.
  16. #16 Re: Should I do the XP Cam or Stage 2 Intercooler??
    Which is insane.
    Did you like the idle of the XP?
    How was the power band as well as the mid range?
  17. #17 Re: Should I do the XP Cam or Stage 2 Intercooler??
    i would also go with an intercooler first, but if he has plans on making this car a monster then a cam would be a better first step.
  18. #18 Re: Should I do the XP Cam or Stage 2 Intercooler??
    Also...powerband for most 3800 cams is midrange...because they don't make much power up top. That damned XP pulled from squat to 6500.
  19. #19 Re: Should I do the XP Cam or Stage 2 Intercooler??
    Well I guess I'm going for an XP instead of an S1X. XP is slightly more "agressive" IRRC right?
  20. #20 Re: Should I do the XP Cam or Stage 2 Intercooler??
    GT Level Member tylerbinski's Avatar
    Canada
    I like my XP cam!
    Wouldn't mind more lump at idle, but i do have stock mufflers on a full 3" exhaust.. also getting a cutout for the spring.. that should cheer me up!
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  1. How to install stage three intercooler?????
    By GINOSGTP in forum General Tech Discussion
    Last Post: 02-25-2009, 07:52 PM
