Ok So I located the boost bypass valve and put on the MAP sensor in the right place on my topswap. The only problem I'm having is that I don't know what wire to splice with the pink wire with comes with the kit from ZZP. I also have no idea where the "ignition on" wires are that they are talking about. Are they talking about the ignition module? (no pink wires there)
Can anyone help that has done this before? Maybe you have pictures (then it would be my lucky day)
Thanks in advance and it sounds real nice when I started it up. Just have to test the gears tomorrow, was too tired tonight to see if I didn't change out the gear shift cable properly.
