Thread: Boost Bypass Valve help
Results 1 to 3 of 3
  1. #1 Boost Bypass Valve help
    Nov 2009
    Brooklyn NY
    Ok So I located the boost bypass valve and put on the MAP sensor in the right place on my topswap. The only problem I'm having is that I don't know what wire to splice with the pink wire with comes with the kit from ZZP. I also have no idea where the "ignition on" wires are that they are talking about. Are they talking about the ignition module? (no pink wires there)
    Can anyone help that has done this before? Maybe you have pictures (then it would be my lucky day)
    Thanks in advance and it sounds real nice when I started it up. Just have to test the gears tomorrow, was too tired tonight to see if I didn't change out the gear shift cable properly.
  2. #2 Re: Boost Bypass Valve help
    you dont need that. leave the BBV unhooked and run by vacuum. real up more in the top swap thread if you want to know how exactly and why.
  3. #3 Re: Boost Bypass Valve help
    Nov 2009
    Brooklyn NY
    Thanks again and ok, will try that. Searching in the forums now.
  1. Boost BYpass Valve capped Off?????
    By Uno99 in forum General Tech Discussion
    Last Post: 10-19-2009, 07:48 PM
  2. m90 bypass valve question
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-04-2009, 04:44 PM
  3. Boost Bypass Valve Questions....
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2008, 08:25 AM
