Thread: Flywheel position
Results 1 to 3 of 3
  1. #1 Flywheel position
    Apr 2009
    stockton ca
    I didnt look all that well but i know the fly wheel had a weight for balance
    does it only bolt on one way. It said to mark it during tear down and i did along with the crank balancer but I then media blasted it and lost my mark and it looks like i have two choices on how it will bolt up
    Any help in this area
  2. #2 Re: Flywheel position
    It will only bolt on one way. But...start and turn each bolt by hand a good number of turns. If any are tight, it's not on properly.
  3. #3 Re: Flywheel position
    Apr 2009
    stockton ca
    ok cool i figured it was a one wasy deal but ive seen some that bolt in any way so i wanted to double check
  1. Crank Pulley out of Position
    By marcheer in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-26-2011, 02:43 PM
  2. cam position sensor
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-18-2009, 02:16 PM
  3. is the flexplate the same thing as the flywheel?
    By 98bdgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-19-2009, 12:50 PM
  4. Steering Wheel Position?
    By eXceL(FAM) in forum Brakes/Suspension/Chassis
    Last Post: 12-06-2008, 12:39 PM
  5. IAC Position
    By Reptile in forum PCM Tuning
    Last Post: 03-08-2008, 02:21 PM
