Thread: Noisy Supercharger. Bad Coupler?
Results 1 to 4 of 4
  1. #1 Noisy Supercharger. Bad Coupler?
    GTX Level Member JoelW98GTP's Avatar
    Nov 2009
    Portsmouth, OH
    My coupler needs replaced and I was just doing some research and it seems like a lot of people have trouble distinguishing where it's the Idle Air Control Valve making the noise which is normal, or your supercharger couple is worn out and which is the culprit of the "rocks tumbling" sound. You can put your ear to the snout of the supercharger to verify where the sound is coming from. Here are two videos on you tube. The first one is the sound of a bad coupler. This sound is audible at an idle only. The second video is showing how to replace the coupler. I hope this helps somebody solve the problem.
    Bad Coupler Noise:
    YouTube - Supercharger noise
    How To Replace The Coupler
    YouTube - Replacing a worn out supercharger coupler on 3.8 GM engines
    98 GTP - Autolite 104s, wires, 180* t-stat, fwi, catless dp and plog, glasspack res, Reptile tuned PCM, tinted tails.
    91 Toyota MR2 Turbo - 327RWHP 322RWTQ 11.48@122mph
    03 BMW 325i - tint. stock.
  2. #2 Re: Noisy Supercharger. Bad Coupler?
    the "tumbling rocks" is a bad coupler.
    the "dragging a shovel on conrete" is the sound the IAC makes when the car is first started and is cold.
    two completely different sounds.
  3. #3 Re: Noisy Supercharger. Bad Coupler?
    Charles City, IA
    But your ear by the snout and see if the noise is coming from there.
    SMGPFC Two Nipple General
  4. #4 Re: Noisy Supercharger. Bad Coupler?
    Nov 2009
    Portsmouth, OH
    I took it as if the shovel would kind of be bouncing as you were dragging it along rough concrete making the pecking sound. I made a couple changes to include both of your suggestions. Thanks
  1. Noisy supercharger at air intake
    By Purple Plazma in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 09:46 AM
  2. Where to get a supercharger snout rebuild kit? (bearings, coupler, etc)
    By PCweber in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2009, 11:36 PM
  3. supercharger coupler ?
    By smokingjoe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2009, 11:19 AM
  4. noisy flex
    Last Post: 04-11-2009, 01:22 AM
  5. supercharger coupler
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2008, 04:41 PM
